Date/Time: Wed, 12 Feb 2025 04:31:00 +0000
repeating date lines
View Count: 649
[2020-10-03 07:27:11]
4646ed - Posts: 230
I cant figure out how to have repeating vertical lines at particular dates on a monthly basis without putting them in by hand individually.
For example on the 1st and the 10th and the 20th of every month over 10 years. For multiple instruments.
Can't use Time Lines or Date-Line studies.
Any suggestions?
[2020-10-03 10:45:42]
Sierra_Chart Engineering - Posts: 18391
For something like this you really have to create your own custom study. You could modify the Time Line study:
How to Build an Advanced Custom Study from Source Code
Time Line
Date Time Of Last Edit: 2020-10-03 10:46:42
[2020-10-03 15:22:54]
4646ed - Posts: 230
I'm not a programmer so never mind.
[2020-10-03 17:04:26]
Ackin - Posts: 1865
maybe ....try study Color based on alert condition with alert:
=OR(DAY(BARDATE)=1,DAY(BARDATE)=10,DAY(BARDATE)=20)
[2020-10-03 17:07:23]
Ackin - Posts: 1865
I don't know how you use a large timeframe with how many bars so don't forget to increase the "Number of Bars to Calculate" study in the Colorbar setting to a higher value.
This solution is not effective, but can be used immediately to test what you want to see. If you would like an ACSIL study for this, you can write me a DM.
