Date/Time: Wed, 12 Feb 2025 04:12:01 +0000
Canada trader
View Count: 1409
[2020-10-03 01:45:32] |
User640178 - Posts: 7 |
Hi folks, which broker support Canada trader? Thanks!
[2020-10-03 10:44:41] |
Sierra_Chart Engineering - Posts: 18391 |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
[2020-10-04 19:26:39] |
Emini500, grain, metal I also trade Nasdaq and NYSE stock. Thanks! |
[2020-10-05 06:02:08] |
You would need to use Interactive Brokers: Interactive Brokers Trading Service For reliable market data you will need to use the Denali Exchange Data Feed for the futures data: Denali Exchange Data Feed And you could also use the Sierra Chart Exchange Data Feed for the US equities data: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-05 06:02:40
[2020-10-07 22:54:52] |
Thank you. I just subscribed denali data feed. How can I send order to my Interactive Brokers Paper account? |
[2020-10-08 00:04:01] |
When I set data/service setting - Interactive Brokers (Trading), I would not able to choose SC data. So, with the above setting, am I using denali data or IB data? |
[2020-10-08 08:53:53] |
In response to post #5, follow the step-by-step instructions here: Interactive Brokers Trading Service: Setup Instructions In response to post #6, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
