Date/Time: Wed, 12 Feb 2025 04:22:58 +0000
5 minute chart timing issue
View Count: 536
[2020-10-02 16:10:19] |
User117985 - Posts: 4 |
I am seeing a (about) 41 second delay once the 5 minute bar ends to when the next one begins on both micro S&P and the micro Russell 2000. Please suggest a fix or what I can do to resolve. Should be moving to the next 5 minute price bar with the first trade of the next 5 minute bar. Thanks.
[2020-10-02 18:35:01] |
You could be incorrectly concluding that there is a delay. Refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
