Date/Time: Wed, 12 Feb 2025 04:23:56 +0000
LMAX account downloand problem
View Count: 440
[2020-10-02 15:07:02] |
User76183 - Posts: 69 |
Hello! Ive got a msg when open SC LMAX : " Download failed. Error downloading historical Daily data. Historical data logon error: Data files folder not set for service code: lmax| Username: resetmsc " I havent changed anything in my Gen settings and I have set my folder for Historical data. I tried to reload, delete/download hist/intraday charts, recalculate etc....It didnt help. I have also checked my login data. I have my connection with LMAX but I couldnt donwnload Hist data |
[2020-10-03 11:25:02] |
This has already been resolved. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
