Date/Time: Wed, 12 Feb 2025 04:23:18 +0000
Multiple time intervals for the same instrument in the same chart
View Count: 495
[2020-10-02 08:48:13] |
User706048 - Posts: 1 |
Hi there, I am trading EUR/USD on a 4h interval and I've added the Kijun as a study as well as a SenkouSpan A/B. Now, as the SenkouSpan cloud is basically hiding the bar chart I would like to move SenouSpan underneath the bar chart like the DMI is in my case. Is this possible in SierraChart? And if yes, how? For the same chart, I usually use studies for entry signalsin let's say 4 hours time interval and exit signals in a lower time interval, say 2 hours. Can i insert (or copy) the exactly same 4 hours chart with its studies in the same chart window and change the lower chart to 2 hours time interval? Meaning to have one chart window with two different charts and their studies above with a 4 hours time interval and underneath with a 2 hours time interval. Is this possible and if yes, how? Thanks, Antonio |
[2020-10-02 11:40:56] |
Refer to: Chart Studies: Study Display Order Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
