Date/Time: Wed, 12 Feb 2025 04:17:15 +0000
Outside Bar Alert
View Count: 693
[2020-10-01 20:54:05] |
User473724 - Posts: 3 |
Hi, Just wondering how I would go about finding formula for an outside bar alert on the chart. Thanks |
[2020-10-01 21:50:57] |
John - SC Support - Posts: 37891 |
Refer to the following study: Outside Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-02 20:28:05] |
Hello again, I have already referred to this and simple alert formula but cannot find anything for alert formula for outside bar study. I found the alerts for an inside bar SG1>0 I tried using SG1<0 for an outside bar to see if that worked and it doesn't. I'm a bit stumped :S |
[2020-10-02 20:51:19] |
It's the same alert syntax as for the Inside Bar (SG1 > 0). When the Outside Bar is true, then the Subgraph for the Outside Bar contains the Last price of the bar, otherwise it is 0.
[2020-10-02 21:10:38] |
Thank you so much :)
