Date/Time: Sun, 27 Sep 2026 19:14:36 +0000
Window layout
View Count: 1345
[2020-10-01 20:22:02]
User161549 - Posts: 81
When using the platform on a multiple monitor setup, everytime I close and re open the platform all my detached windows move back to the main default screen
I also experience the same issue if I switch between another chartbook
Is there anyway to lock in a certain layout that will automatically place the charts around accordingly when opening the platform instead of having to do it manually each time ?
[2020-10-02 05:42:33]
Refer to:
Window Size and Position Not Restored When Opening Chartbook
You can thank Microsoft for your troubles. This is with 110% certainty.
Date Time Of Last Edit: 2020-10-02 05:42:56
[2020-10-05 20:11:13]
Okay I have a better understanding of the issue now, Thank you
In regards to me having that issue when i switch between chartbooks because of this I would just have to put all my charts on one chartbook but in return it has dramatically slowed the performance
down of my DOM and footprint charts, I do have my chart update interval in milliseconds set to 10 but other than that is there anything else i can do or settings i can change to improve the speed of
some of my smaller time frame charts
