Date/Time: Wed, 12 Feb 2025 01:40:28 +0000
How To Split Shares/Contracts/Slots Size On A Footprint Chart (Number Bars)?
View Count: 672
[2020-10-01 18:08:22] |
Nkrastins - Posts: 35 |
Hello, beginner here, I was searching through the site for the answer, but I couldn't find it. My question is how can I split/divide traded large amounts into smaller ones? Like 50 000 or 50K into 10/100/1000 times smaller size 5000/500/50 So my chart doesn't look 13.4k X 9289 11.2K X 18.7K 7628 X 14.2K 120 X 1672 89 X 9 but, instead 134 X 93 112 X 187 76 X 142 1 X 167 0 X 0 I am asking because some of the stocks that I trade are traded 10s millions of shares, and very often you will have 10s of thousands of shares traded at each level, which at times is hard to determine what is a strong net delta because I am used to seeing 300-500 deltas when trading e-minis. Thanks |
[2020-10-01 18:52:02] |
John - SC Support - Posts: 37891 |
Refer to the documentation for the Volume/Open Interest Multiplier here: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
