Date/Time: Wed, 12 Feb 2025 01:20:34 +0000
[User Discussion] - Multiple Accounts
View Count: 495
[2020-10-01 16:39:13]
Mattc55 - Posts: 97
I was wondering if it is possible, if I had two accounts on the same feed with same broker, could the chart trader simultaneously be opened and trading in both accounts on two separate markets?
For risk purposes, i'm trying to set a broker level daily loss limit and auto liquidate for ES and CL and the risk limits ideally need to be independent of one another.
Hopefully that makes sense.
In one instance, i'd like to trade CL on one chartbook in one account and ES in another chartbook and another account.
THanks in advance
[2020-10-01 17:06:28]
John - SC Support - Posts: 37891
Yes, you can do this. If the accounts are under the same login information with your broker then they should be available to Sierra Chart, in which case you would need to select the particular account that you want to place the trade with on the Trade Window. Refer to the information here:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
