Date/Time: Wed, 12 Feb 2025 04:15:54 +0000
connected but no data coming through.
View Count: 509
[2020-10-01 16:01:07] |
cache.capital - Posts: 7 |
Hi, I had data coming through when at home but I took my laptop to work and tried to login via the network. Since then I am unable to access any data feed anywhere. Initially i was told it was because I had 2 instances of sierra open, I do not. I have tried changing the fierwall settings but that has not worked, shutting down and reopening Sierra but nothing is coming through. Please help! Mat |
[2020-10-01 16:18:18] |
Ho do I get market order flow showing up on DOM?
[2020-10-02 07:48:01] |
Refer to this thread about this: Not Receiving Delayed Exchange Data Feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-02 07:48:07
