Date/Time: Wed, 12 Feb 2025 01:38:40 +0000
Fix order fills
View Count: 520
[2020-10-01 16:00:55]
User873130 - Posts: 47
Hi
running SC 2175, my order execution fills are all over the place where an exit is now an entry and what was an entry is now an exit. How do i Fix this? thank you
[2020-10-01 20:49:45]
Refer to the information here regarding this:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities (Accurate Entry/Exit State, Fill Matching and Position Quantities)
