Date/Time: Wed, 12 Feb 2025 11:37:07 +0000
BMF real-time data not loading correctly
View Count: 27379
[2020-10-01 14:07:00] |
User143517 - Posts: 68 |
Hi there, I signed up for BMF real-time data today, and I am following 2 of its markets, which are XDX20 and XEX20 symbols. However, I am noticing some big delays/dislocations between the current data which is being shown and other local platforms. Could you check if Barchart is experiencing some issues with it? If they are the ones who are still feeding this data?(I remember a while ago they were the ones providing it) Thanks, Joao. |
[2020-10-01 15:19:50] |
FWIW, this is happening on a 2nd instance of SC connected to SC Data - All Services service.
[2020-10-02 08:10:48] |
Are the two instances connected at the same time? They cannot be. Only one will receive real-time data.
[2020-10-02 10:13:08] |
The 1st one is connected to SC Futures Order Routing/Data [trading], and I am using Denali exchange data feed, as I am using it to trade CME products. Would that be a problem too?
Date Time Of Last Edit: 2020-10-02 10:14:06
[2020-10-02 12:46:48] |
As an additional info, I disconnected SC Futures Order Routing/Data[trading] and only connected the 2nd insntance with SC Data - all services and this issue is persisting. Here follows the message log: Reading Internal Order ID file. | 2020-10-02 07:17:02.121 Reading Trade Orders file. | 2020-10-02 07:17:02.189 Reading Trade Positions file. | 2020-10-02 07:17:02.189 Reading Account Balance file. | 2020-10-02 07:17:02.189 UDPListener (1312). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Normalmente é permitida apenas uma utilização de cada endereço de soquete (protocolo/endereço de rede/porta). | 2020-10-02 07:17:02.204 Software version: 2175 64-bit | 2020-10-02 07:17:02.204 Primary Thread ID: 34136 | 2020-10-02 07:17:02.204 Usage end date: 2021-01-17 | 2020-10-02 07:17:02.204 Enabled for: Advanced Features 2. | 2020-10-02 07:17:02.204 Enabled for: Sierra Chart Historical Data Service. | 2020-10-02 07:17:02.204 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-10-02 07:17:02.204 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-02 07:17:02.204 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-02 07:17:02.204 Enabled for exchange: BM&F Futures | 2020-10-02 07:17:02.204 Enabled for exchange2: CME (Trading Account Required) | 2020-10-02 07:17:02.204 Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-02 07:17:02.204 Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-02 07:17:02.204 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-02 07:17:02.204 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-02 07:17:02.204 Current selected Data/Trading service: SC Data - All Services | 2020-10-02 07:17:02.204 Custom symbol settings values: enabled | 2020-10-02 07:17:02.204 Chart Update Interval: 500 | 2020-10-02 07:17:02.204 Intraday Data Storage Time Unit: 0 | 2020-10-02 07:17:02.204 Time Zone: -03:00:00 (UTC-03) | 2020-10-02 07:17:02.204 2020-10-02 07:17:02 Local computer time | 2020-10-02 07:17:02.204 2020-10-02 10:17:02 Local computer time in UTC | 2020-10-02 07:17:02.204 2020-10-02 07:17:02 Local computer time in SC Time Zone | 2020-10-02 07:17:02.204 2020-10-02 10:17:00 Server time in UTC | 2020-10-02 07:17:02.204 Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-10-02 07:17:02.204 Program path: C:\SierraChart2\ | 2020-10-02 07:17:02.204 Data Files path: C:\SierraChart2\Data\ | 2020-10-02 07:17:02.204 OS Version Number: 10.0 | 2020-10-02 07:17:02.204 Locale Setting: C | 2020-10-02 07:17:02.204 DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-02 07:17:02.205 Allowed protected custom studies: SST_FreeBundle | 2020-10-02 07:17:02.205 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-10-02 07:17:02.218 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-02 07:17:02.234 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-02 07:17:02.435 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-02 07:17:02.435 Received 5 login tokens. | 2020-10-02 07:17:02.906 Symbol settings MD5 received. Request ID: 1. | 2020-10-02 07:17:03.515 Requested symbol settings for service code scdataallservices. Request ID: 2. | 2020-10-02 07:17:03.515 Symbol settings received. Request ID: 2. | 2020-10-02 07:17:05.425 SC Data - All Services | Connected to server complete. | 2020-10-02 07:17:08.126 Triggering next historical data download in queue. | 2020-10-02 07:17:08.126 Triggering next historical data download in queue. | 2020-10-02 07:17:08.126 Triggering next historical data download in queue. | 2020-10-02 07:17:08.126 Triggering next historical data download in queue. | 2020-10-02 07:17:08.126 Triggering next historical data download in queue. | 2020-10-02 07:17:08.126 XEX20 [CBV] 0.04 Range #1 | Reloading chart. | 2020-10-02 07:17:20.509 XEX20 [CBV] 0.04 Range #1 | Performing historical Daily data download for symbol XEX20 starting at last date in file. | 2020-10-02 07:17:20.580 Starting DelayedDownloadMonitoringTimer | 2020-10-02 07:17:20.580 Starting HDTimeoutTimer | 2020-10-02 07:17:20.580 Added historical Daily data request for XEX20 to the queue. | 2020-10-02 07:17:20.580 Triggering next historical data download in queue. | 2020-10-02 07:17:20.580 XEX20 [CBV] 0.04 Range #1 | Waiting for historical downloads to complete with the IDs: 1, | 2020-10-02 07:17:20.598 Loading DLL C:\SierraChart2\Data\UserContributedStudies_64.dll | 2020-10-02 07:17:20.603 XEX20 [CBV] 50 Volume #2 | Reloading chart. | 2020-10-02 07:17:20.718 Starting DelayedDownloadMonitoringTimer | 2020-10-02 07:17:20.800 Starting HDTimeoutTimer | 2020-10-02 07:17:20.800 Added historical Intraday data request for XEQ20 to the queue. | 2020-10-02 07:17:20.800 Triggering next historical data download in queue. | 2020-10-02 07:17:20.800 XEX20 [CBV] 50 Volume #2 | Performing historical Daily data download for symbol XEQ20 starting at last date in file. | 2020-10-02 07:17:20.803 Added historical Daily data request for XEQ20 to the queue. | 2020-10-02 07:17:20.803 XEX20 [CBV] 50 Volume #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:20.872 XEX20 [CBV] 100 Volume #4 | Reloading chart. | 2020-10-02 07:17:20.893 XEX20 [CBV] 100 Volume #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:20.958 XEX20 [CBV] 500 Volume #5 | Reloading chart. | 2020-10-02 07:17:20.969 XEX20 [CBV] 500 Volume #5 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.033 XEX20 [CBV] Daily #6 | Reloading chart. | 2020-10-02 07:17:21.044 XEX20 [CBV] Daily #6 | Performing historical Daily data download for symbol XEQ17 starting at last date in file. | 2020-10-02 07:17:21.078 Added historical Daily data request for XEQ17 to the queue. | 2020-10-02 07:17:21.078 XEX20 [CBV] Daily #6 | Performing historical Daily data download for symbol XEQ18 starting at last date in file. | 2020-10-02 07:17:21.139 Added historical Daily data request for XEQ18 to the queue. | 2020-10-02 07:17:21.139 XEX20 [CBV] Daily #6 | Performing historical Daily data download for symbol XEQ19 starting at last date in file. | 2020-10-02 07:17:21.190 Added historical Daily data request for XEQ19 to the queue. | 2020-10-02 07:17:21.190 XEX20 [CBV] Daily #6 | File XEN18.dly has a volume of 0 at 2018-07-13. | 2020-10-02 07:17:21.382 XEX20 [CBV] Daily #6 | File XEN17.dly has a volume of 0 at 2017-05-15. | 2020-10-02 07:17:21.444 XEX20 [CBV] Daily #6 | File XEN17.dly has a volume of 0 at 2017-07-14. | 2020-10-02 07:17:21.444 XEX20 [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 1, 3, 4, 5, 6, | 2020-10-02 07:17:21.488 XEX20 [CBV] 750 Volume #7 | Reloading chart. | 2020-10-02 07:17:21.498 XEX20 [CBV] 750 Volume #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.563 XEX20 [CBV] 50 Volume #8 | Reloading chart. | 2020-10-02 07:17:21.589 XEX20 [CBV] 50 Volume #8 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.653 XEX20 [CBV] 20 Volume #9 | Reloading chart. | 2020-10-02 07:17:21.675 XEX20 [CBV] 20 Volume #9 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.739 XEX20 [CBV] 50 Volume #11 | Reloading chart. | 2020-10-02 07:17:21.761 XEX20 [CBV] 50 Volume #11 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.826 XEX20 [CBV] 5 Min #12 | Reloading chart. | 2020-10-02 07:17:21.848 XEX20 [CBV] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.913 XEX20 [CBV] #16 | Reloading chart. | 2020-10-02 07:17:21.930 XEX20 [CBV] #16 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:21.995 XEX20 [CBV] Renko 5t #3 | Reloading chart. | 2020-10-02 07:17:22.017 XEX20 [CBV] Renko 5t #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, | 2020-10-02 07:17:22.082 Mapping XEX20 to XEX20. Service code: bmf.exchange | 2020-10-02 07:17:22.087 HD Request # 1 | Downloading Historical Daily chart data for XEX20. Starting date: 2020-09-29. Service: bmf.exchange | 2020-10-02 07:17:22.089 HD Request # 1 | Requesting historical Daily data for XEX20 starting at 2020-09-28. SC External HD service. | 2020-10-02 07:17:22.089 Mapping XEQ20 to XEQ20. Service code: bmf.exchange | 2020-10-02 07:17:22.090 HD Request # 2 | Downloading Intraday chart data for XEQ20 to the file XEQ20.scid. Service: bmf.exchange | 2020-10-02 07:17:22.090 Enabling compression for file: C:\SierraChart2\Data\XEQ20.scid. This may take a while. | 2020-10-02 07:17:22.090 HD Request # 2 | Download start date-time: 2020-06-29 21:00:00.000 | 2020-10-02 07:17:22.090 HD Request # 2 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-10-02 07:17:22.090 Socket (2) | Creating socket. | 2020-10-02 07:17:22.164 Socket (2) | New receive buffer size: 5242880 | 2020-10-02 07:17:22.165 Socket (2) | Connecting to IP: 8.18.161.133. | 2020-10-02 07:17:22.165 HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-10-02 07:17:22.485 HD Request # 2 | Sending historical data logon request message. | 2020-10-02 07:17:22.485 HD Request # 2 | Requesting Intraday data. Start date-time: 2020-06-29 21:00:00. Record interval: 0. Symbol: XEQ20 | 2020-10-02 07:17:23.171 Socket (2) | CloseSocket call. | 2020-10-02 07:17:23.331 Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-02 07:17:23.331 HD Request # 2 | Error downloading historical Intraday data for XEQ20. Historical data file not available for symbol. | 2020-10-02 07:17:23.331 Historical data download thread signaled to stop. | 2020-10-02 07:17:23.331 HD Request # 2 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for XEQ20 | 2020-10-02 07:17:23.331 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-02 07:17:23.331 HD Request # 2 | Completion time: 1s | 2020-10-02 07:17:23.333 HD Request # 2 | Intraday data download complete for XEQ20. Unique request ID: 2 | 2020-10-02 07:17:23.333 Removing historical data download ID 2. | 2020-10-02 07:17:23.333 Real-time Intraday chart data file updates started for XEQ20 | 2020-10-02 07:17:23.333 Intraday chart data file opened for XEQ20 | 2020-10-02 07:17:23.333 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2020-10-02 07:17:23.333 Triggering next historical data download in queue. | 2020-10-02 07:17:23.333 Socket (2) | Socket gracefully closed by remote side. | 2020-10-02 07:17:23.471 Socket (2) | Closed. | 2020-10-02 07:17:23.471 HD Request # 1 | Receiving historical Daily data for XEX20 starting at 2020-09-29 | 2020-10-02 07:17:23.625 HD Request # 1 | Writing historical Daily data to the file XEX20.dly | 2020-10-02 07:17:23.626 HD Request # 1 | Bytes received: 248 | 2020-10-02 07:17:23.628 HD Request # 1 | Received 5 records from 2020-09-29 00:00:00 to 2020-10-02 00:00:00 (4.0 days) and wrote 4 records for XEX20 | 2020-10-02 07:17:23.628 HD Request # 1 | Completion time: 1s | 2020-10-02 07:17:23.628 HD Request # 1 | Daily data download complete for XEX20. Unique request ID: 1 | 2020-10-02 07:17:23.628 Removing historical data download ID 1. | 2020-10-02 07:17:23.628 Triggering next historical data download in queue. | 2020-10-02 07:17:23.628 HD Request # 3 | Downloading Historical Daily chart data for XEQ20. Starting date: 1970-10-02. Service: bmf.exchange | 2020-10-02 07:17:23.629 HD Request # 3 | Requesting historical Daily data for XEQ20 starting at 1970-10-01. SC External HD service. | 2020-10-02 07:17:23.629 XEX20 [CBV] 0.04 Range #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:24.028 XEX20 [CBV] 0.04 Range #1 | Reloading chart. | 2020-10-02 07:17:24.029 XEX20 [CBV] 0.04 Range #1 | Reloading chart. | 2020-10-02 07:17:24.525 SC Data - All Services | Starting real-time market data updates for: XEX20 (XEX20). ID: 1 Service code: bmf.exchange | 2020-10-02 07:17:25.037 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2020-10-02 07:17:25.037 SC Data - All Services | Requesting security definition data for: XEX20 (XEX20). ID: 1 | 2020-10-02 07:17:25.037 Added historical Intraday data request for XEX20 to the queue. | 2020-10-02 07:17:25.037 Intraday data recording state for symbol XEX20 is set to download 'Pending'. | 2020-10-02 07:17:25.037 Triggering next historical data download in queue. | 2020-10-02 07:17:25.037 Delaying start of download for XEX20 | 2020-10-02 07:17:25.038 HD Request # 3 | Bytes received: 4 | 2020-10-02 07:17:25.170 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XEQ20 | 2020-10-02 07:17:25.170 HD Request # 3 | Completion time: 2s | 2020-10-02 07:17:25.170 HD Request # 3 | Daily data download complete for XEQ20. Unique request ID: 3 | 2020-10-02 07:17:25.170 Removing historical data download ID 3. | 2020-10-02 07:17:25.170 Triggering next historical data download in queue. | 2020-10-02 07:17:25.170 Mapping XEQ17 to XEQ17. Service code: bmf.exchange | 2020-10-02 07:17:25.170 HD Request # 4 | Downloading Historical Daily chart data for XEQ17. Starting date: 1970-10-02. Service: bmf.exchange | 2020-10-02 07:17:25.170 HD Request # 4 | Requesting historical Daily data for XEQ17 starting at 1970-10-01. SC External HD service. | 2020-10-02 07:17:25.170 XEX20 [CBV] 20 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.194 XEX20 [CBV] 20 Volume #9 | Reloading chart. | 2020-10-02 07:17:25.194 XEX20 [CBV] 20 Volume #9 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.250 XEX20 [CBV] 20 Volume #9 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.250 XEX20 [CBV] 50 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.261 XEX20 [CBV] 50 Volume #2 | Reloading chart. | 2020-10-02 07:17:25.262 XEX20 [CBV] 50 Volume #2 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.386 XEX20 [CBV] 50 Volume #2 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.386 XEX20 [CBV] 20 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:25.398 XEX20 [CBV] 50 Volume #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.403 XEX20 [CBV] 50 Volume #11 | Reloading chart. | 2020-10-02 07:17:25.403 XEX20 [CBV] 50 Volume #11 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.447 XEX20 [CBV] 50 Volume #11 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.448 XEX20 [CBV] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.459 XEX20 [CBV] 5 Min #12 | Reloading chart. | 2020-10-02 07:17:25.459 DTC Client socket (3) | Creating socket. | 2020-10-02 07:17:25.504 DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-02 07:17:25.504 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2020-10-02 07:17:25.504 XEX20 [CBV] 5 Min #12 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.505 XEX20 [CBV] 5 Min #12 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.505 XEX20 [CBV] 50 Volume #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:25.516 XEX20 [CBV] 50 Volume #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:25.536 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:25.550 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:25.581 XEX20 [CBV] 100 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.582 XEX20 [CBV] 100 Volume #4 | Reloading chart. | 2020-10-02 07:17:25.582 XEX20 [CBV] 100 Volume #4 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.626 XEX20 [CBV] 100 Volume #4 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.626 XEX20 [CBV] 5 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:25.637 SC Data - All Services | Network connection to server complete. | 2020-10-02 07:17:25.702 SC Data - All Services | Starting socket receive thread. | 2020-10-02 07:17:25.702 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-02 07:17:25.702 XEX20 [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.703 XEX20 [CBV] #16 | Reloading chart. | 2020-10-02 07:17:25.704 XEX20 [CBV] #16 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.748 XEX20 [CBV] #16 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.748 XEX20 [CBV] 500 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.783 XEX20 [CBV] 500 Volume #5 | Reloading chart. | 2020-10-02 07:17:25.784 XEX20 [CBV] 500 Volume #5 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.829 XEX20 [CBV] 500 Volume #5 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.829 XEX20 [CBV] 750 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.855 XEX20 [CBV] 750 Volume #7 | Reloading chart. | 2020-10-02 07:17:25.855 XEX20 [CBV] 750 Volume #7 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.899 XEX20 [CBV] 750 Volume #7 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.900 XEX20 [CBV] Renko 5t #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.927 XEX20 [CBV] Renko 5t #3 | Reloading chart. | 2020-10-02 07:17:25.928 XEX20 [CBV] Renko 5t #3 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.972 XEX20 [CBV] Renko 5t #3 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:25.972 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-02 07:17:25.996 SC Data - All Services | Sending logon request message. | 2020-10-02 07:17:25.996 XEX20 [CBV] 50 Volume #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:25.997 XEX20 [CBV] 50 Volume #8 | Reloading chart. | 2020-10-02 07:17:25.997 XEX20 [CBV] 50 Volume #8 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.041 XEX20 [CBV] 50 Volume #8 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.042 XEX20 [CBV] 20 Volume #9 | Reloading chart. | 2020-10-02 07:17:26.054 XEX20 [CBV] 20 Volume #9 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.165 XEX20 [CBV] 20 Volume #9 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.165 XEX20 [CBV] Renko 5t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.177 XEX20 [CBV] 50 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.224 XEX20 [CBV] 20 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.281 XEX20 [CBV] 50 Volume #2 | Reloading chart. | 2020-10-02 07:17:26.285 XEX20 [CBV] 50 Volume #2 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.395 XEX20 [CBV] 50 Volume #2 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.395 XEX20 [CBV] 50 Volume #11 | Reloading chart. | 2020-10-02 07:17:26.407 XEX20 [CBV] 50 Volume #11 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.515 XEX20 [CBV] 50 Volume #11 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.516 XEX20 [CBV] 50 Volume #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.527 XEX20 [CBV] 5 Min #12 | Reloading chart. | 2020-10-02 07:17:26.563 XEX20 [CBV] 5 Min #12 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.672 XEX20 [CBV] 5 Min #12 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.672 XEX20 [CBV] 50 Volume #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.683 Chart #11 has tagged chart #12 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:26.696 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:26.696 Chart #11 has tagged chart #3 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:26.696 XEX20 [CBV] 100 Volume #4 | Reloading chart. | 2020-10-02 07:17:26.711 XEX20 [CBV] 100 Volume #4 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.820 XEX20 [CBV] 100 Volume #4 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:26.820 XEX20 [CBV] 5 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:26.831 SC Data - All Services | Received logon response. | 2020-10-02 07:17:26.863 SC Data - All Services | Server Name: SC Realtime Server. | 2020-10-02 07:17:26.863 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-02 07:17:26.863 SC Data - All Services | Successfully connected. | 2020-10-02 07:17:26.863 SC Data - All Services | Trading is not supported. | 2020-10-02 07:17:26.863 SC Data - All Services | Restarting real-time data updates for symbol: XEX20 -> XEX20 | 2020-10-02 07:17:26.863 XEX20 [CBV] #16 | Reloading chart. | 2020-10-02 07:17:26.918 XEX20 [CBV] #16 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.028 XEX20 [CBV] #16 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.028 HD Request # 4 | Bytes received: 4 | 2020-10-02 07:17:27.039 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XEQ17 | 2020-10-02 07:17:27.039 HD Request # 4 | Completion time: 2s | 2020-10-02 07:17:27.039 HD Request # 4 | Daily data download complete for XEQ17. Unique request ID: 4 | 2020-10-02 07:17:27.039 Removing historical data download ID 4. | 2020-10-02 07:17:27.039 Triggering next historical data download in queue. | 2020-10-02 07:17:27.039 Mapping XEQ18 to XEQ18. Service code: bmf.exchange | 2020-10-02 07:17:27.039 HD Request # 5 | Downloading Historical Daily chart data for XEQ18. Starting date: 1970-10-02. Service: bmf.exchange | 2020-10-02 07:17:27.040 HD Request # 5 | Requesting historical Daily data for XEQ18 starting at 1970-10-01. SC External HD service. | 2020-10-02 07:17:27.040 XEX20 [CBV] 500 Volume #5 | Reloading chart. | 2020-10-02 07:17:27.041 XEX20 [CBV] 500 Volume #5 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.150 XEX20 [CBV] 500 Volume #5 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.151 SC Data - All Services | Received security definition for symbol XEX20 | 2020-10-02 07:17:27.175 XEX20 [CBV] 750 Volume #7 | Reloading chart. | 2020-10-02 07:17:27.176 XEX20 [CBV] 750 Volume #7 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.285 XEX20 [CBV] 750 Volume #7 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.285 XEX20 [CBV] Renko 5t #3 | Reloading chart. | 2020-10-02 07:17:27.314 XEX20 [CBV] Renko 5t #3 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.423 XEX20 [CBV] Renko 5t #3 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.423 XEX20 [CBV] 50 Volume #8 | Reloading chart. | 2020-10-02 07:17:27.447 XEX20 [CBV] 50 Volume #8 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.556 XEX20 [CBV] 50 Volume #8 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:27.556 XEX20 [CBV] Renko 5t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:27.567 XEX20 [CBV] 50 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-10-02 07:17:27.642 XEX20 [CBV][M] 50 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:27.661 HD Request # 5 | Bytes received: 4 | 2020-10-02 07:17:29.190 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XEQ18 | 2020-10-02 07:17:29.190 HD Request # 5 | Completion time: 2s | 2020-10-02 07:17:29.190 HD Request # 5 | Daily data download complete for XEQ18. Unique request ID: 5 | 2020-10-02 07:17:29.190 Removing historical data download ID 5. | 2020-10-02 07:17:29.190 Triggering next historical data download in queue. | 2020-10-02 07:17:29.190 Mapping XEQ19 to XEQ19. Service code: bmf.exchange | 2020-10-02 07:17:29.190 HD Request # 6 | Downloading Historical Daily chart data for XEQ19. Starting date: 1970-10-02. Service: bmf.exchange | 2020-10-02 07:17:29.191 HD Request # 6 | Requesting historical Daily data for XEQ19 starting at 1970-10-01. SC External HD service. | 2020-10-02 07:17:29.191 HD Request # 6 | Bytes received: 4 | 2020-10-02 07:17:30.762 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XEQ19 | 2020-10-02 07:17:30.762 HD Request # 6 | Completion time: 1s | 2020-10-02 07:17:30.762 HD Request # 6 | Daily data download complete for XEQ19. Unique request ID: 6 | 2020-10-02 07:17:30.762 Removing historical data download ID 6. | 2020-10-02 07:17:30.762 Triggering next historical data download in queue. | 2020-10-02 07:17:30.762 XEX20 [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-02 07:17:31.072 XEX20 [CBV] Daily #6 | Reloading chart. | 2020-10-02 07:17:31.076 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2017-07-20 from file. C:\SierraChart2\Data\XEQ17.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.231 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2017-08-18 from file. C:\SierraChart2\Data\XEQ17.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.231 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2018-07-19 from file. C:\SierraChart2\Data\XEQ18.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.266 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2018-08-18 from file. C:\SierraChart2\Data\XEQ18.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.266 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2019-07-19 from file. C:\SierraChart2\Data\XEQ19.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.302 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2019-08-18 from file. C:\SierraChart2\Data\XEQ19.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.303 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.330 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:31.330 XEX20 [CBV] Daily #6 | Reloading chart. | 2020-10-02 07:17:31.574 XEX20 [CBV] Daily #6 | File XEN18.dly has a volume of 0 at 2018-07-13. | 2020-10-02 07:17:31.754 XEX20 [CBV] Daily #6 | File XEN17.dly has a volume of 0 at 2017-05-15. | 2020-10-02 07:17:31.817 XEX20 [CBV] Daily #6 | File XEN17.dly has a volume of 0 at 2017-07-14. | 2020-10-02 07:17:31.817 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2017-07-20 from file. C:\SierraChart2\Data\XEQ17.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.014 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2017-08-18 from file. C:\SierraChart2\Data\XEQ17.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.015 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2018-07-19 from file. C:\SierraChart2\Data\XEQ18.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.048 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2018-08-18 from file. C:\SierraChart2\Data\XEQ18.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.048 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2019-07-19 from file. C:\SierraChart2\Data\XEQ19.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.084 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2019-08-18 from file. C:\SierraChart2\Data\XEQ19.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.084 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2020-07-18 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.112 XEX20 [CBV] Daily #6 | Error while getting daily open price with date 2020-08-20 from file. C:\SierraChart2\Data\XEQ20.dly. Error: No Data for read. End of file. | 2020-10-02 07:17:32.112 HD Request # 7 | Downloading Intraday chart data for XEX20 to the file XEX20.scid. Service: bmf.exchange | 2020-10-02 07:17:32.127 Enabling compression for file: C:\SierraChart2\Data\XEX20.scid. This may take a while. | 2020-10-02 07:17:32.127 HD Request # 7 | Download start date-time: 2020-10-01 18:04:28.000 | 2020-10-02 07:17:32.127 HD Request # 7 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-10-02 07:17:32.127 Socket (7) | Creating socket. | 2020-10-02 07:17:32.149 Socket (7) | New receive buffer size: 5242880 | 2020-10-02 07:17:32.149 Socket (7) | Connecting to IP: 8.18.161.135. | 2020-10-02 07:17:32.149 HD Request # 7 | Setting DTC encoding to Binary VLS | 2020-10-02 07:17:32.466 HD Request # 7 | Sending historical data logon request message. | 2020-10-02 07:17:32.466 HD Request # 7 | Requesting Intraday data. Start date-time: 2020-10-01 18:04:28. Record interval: 0. Symbol: XEX20 | 2020-10-02 07:17:33.126 HD Request # 7 | Decompressing data. | 2020-10-02 07:17:33.281 HD Request # 7 | Receiving Intraday data for XEX20 starting at 2020-10-01 18:04:28.717000 | 2020-10-02 07:17:33.281 Socket (7) | CloseSocket call. | 2020-10-02 07:17:33.282 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-02 07:17:33.282 Socket (7) | Shutdown started. Waiting for graceful close. | 2020-10-02 07:17:33.282 Historical data download thread signaled to stop. | 2020-10-02 07:17:33.282 HD Request # 7 | Timestamp of first Intraday data file record written: 2020-10-01 18:04:28.717002 | 2020-10-02 07:17:33.282 HD Request # 7 | Received 2 records from 2020-10-01 18:04:28.717 to 2020-10-01 18:04:28.717 (0.0 seconds) and wrote 2 records for XEX20 | 2020-10-02 07:17:33.282 HD Request # 7 | Completion time: 1s | 2020-10-02 07:17:33.283 HD Request # 7 | Intraday data download complete for XEX20. Unique request ID: 7 | 2020-10-02 07:17:33.283 Removing historical data download ID 7. | 2020-10-02 07:17:33.283 Real-time Intraday chart data file updates started for XEX20 | 2020-10-02 07:17:33.283 Intraday chart data file opened for XEX20 | 2020-10-02 07:17:33.283 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2020-10-02 07:17:33.283 Triggering next historical data download in queue. | 2020-10-02 07:17:33.283 Socket (7) | Socket gracefully closed by remote side. | 2020-10-02 07:17:33.420 Socket (7) | Closed. | 2020-10-02 07:17:33.420 Chart #11 has tagged chart #12 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.452 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.452 Chart #11 has tagged chart #3 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.452 XEX20 [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.592 XEX20 [CBV][M] 50 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.858 XEX20 [CBV][M] Renko 5t #3 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:17:33.878 SC Data - All Services | Real-time data for symbol XEX20 is currently unavailable. | 2020-10-02 07:57:14.150 SC Data - All Services | Received security definition for symbol XEX20 | 2020-10-02 07:57:51.482 SC Data - All Services | Real-time data for symbol XEX20 has been restored. | 2020-10-02 07:57:51.482 Added historical Intraday data request for XEX20 to the queue. | 2020-10-02 07:57:51.482 Intraday data recording state for symbol XEX20 is set to download 'Pending'. | 2020-10-02 07:57:51.482 Triggering next historical data download in queue. | 2020-10-02 07:57:51.482 HD Request # 8 | Downloading Intraday chart data for XEX20 to the file XEX20.scid. Service: bmf.exchange | 2020-10-02 07:57:51.482 Enabling compression for file: C:\SierraChart2\Data\XEX20.scid. This may take a while. | 2020-10-02 07:57:51.482 HD Request # 8 | Download start date-time: 2020-10-01 18:04:28.000 | 2020-10-02 07:57:51.482 HD Request # 8 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-10-02 07:57:51.482 Socket (1) | Creating socket. | 2020-10-02 07:57:51.483 Socket (1) | New receive buffer size: 5242880 | 2020-10-02 07:57:51.483 Socket (1) | Connecting to IP: 8.18.161.133. | 2020-10-02 07:57:51.483 HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-10-02 07:57:51.789 HD Request # 8 | Sending historical data logon request message. | 2020-10-02 07:57:51.789 HD Request # 8 | Requesting Intraday data. Start date-time: 2020-10-01 18:04:28. Record interval: 0. Symbol: XEX20 | 2020-10-02 07:57:52.448 HD Request # 8 | Decompressing data. | 2020-10-02 07:57:52.604 HD Request # 8 | Receiving Intraday data for XEX20 starting at 2020-10-01 18:04:28.717000 | 2020-10-02 07:57:52.605 Socket (1) | CloseSocket call. | 2020-10-02 07:57:52.605 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-02 07:57:52.605 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-02 07:57:52.605 Historical data download thread signaled to stop. | 2020-10-02 07:57:52.605 HD Request # 8 | Timestamp of first Intraday data file record written: 2020-10-01 18:04:28.717004 | 2020-10-02 07:57:52.605 HD Request # 8 | Received 1 record from 2020-10-01 18:04:28.717 to 2020-10-01 18:04:28.717 (0.0 seconds) and wrote 1 record for XEX20 | 2020-10-02 07:57:52.605 HD Request # 8 | Completion time: 1s | 2020-10-02 07:57:52.606 HD Request # 8 | Intraday data download complete for XEX20. Unique request ID: 8 | 2020-10-02 07:57:52.606 Removing historical data download ID 8. | 2020-10-02 07:57:52.606 Real-time Intraday chart data file updates started for XEX20 | 2020-10-02 07:57:52.606 Intraday chart data file opened for XEX20 | 2020-10-02 07:57:52.606 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2020-10-02 07:57:52.606 Triggering next historical data download in queue. | 2020-10-02 07:57:52.606 Socket (1) | Socket gracefully closed by remote side. | 2020-10-02 07:57:52.744 Socket (1) | Closed. | 2020-10-02 07:57:52.744 Chart #11 has tagged chart #12 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.073 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.074 Chart #11 has tagged chart #3 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.074 XEX20 [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.082 XEX20 [CBV][M] 50 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.578 XEX20 [CBV][M] Renko 5t #3 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 07:57:53.600 Opened cached Intraday file: C:\SierraChart2\Data\XEX20.scid. Thread ID: 79496 | 2020-10-02 09:00:12.796 File >> Disconnect selected. | 2020-10-02 09:42:26.736 SC Data - All Services | Waiting for socket receive thread to end | 2020-10-02 09:42:26.738 DTC Client socket (3) | CloseSocket call. | 2020-10-02 09:42:26.738 DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-02 09:42:26.738 SC Data - All Services | Disconnected from the server. | 2020-10-02 09:42:26.739 SC Data - All Services | Disconnected. | 2020-10-02 09:42:26.739 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-02 09:42:26.739 DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-02 09:42:26.878 DTC Client socket (3) | Closed. | 2020-10-02 09:42:26.878 SC Data - All Services | Connected to server complete. | 2020-10-02 09:42:34.838 Triggering next historical data download in queue. | 2020-10-02 09:42:34.839 Triggering next historical data download in queue. | 2020-10-02 09:42:34.839 Triggering next historical data download in queue. | 2020-10-02 09:42:34.839 Triggering next historical data download in queue. | 2020-10-02 09:42:34.839 Triggering next historical data download in queue. | 2020-10-02 09:42:34.839 Mapping XEX20 to XEX20. Service code: bmf.exchange | 2020-10-02 09:42:35.184 SC Data - All Services | Starting real-time market data updates for: XEX20 (XEX20). ID: 1 Service code: bmf.exchange | 2020-10-02 09:42:35.184 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2020-10-02 09:42:35.184 SC Data - All Services | Requesting security definition data for: XEX20 (XEX20). ID: 1 | 2020-10-02 09:42:35.184 Added historical Intraday data request for XEX20 to the queue. | 2020-10-02 09:42:35.185 Intraday data recording state for symbol XEX20 is set to download 'Pending'. | 2020-10-02 09:42:35.185 Triggering next historical data download in queue. | 2020-10-02 09:42:35.185 Delaying start of download for XEX20 | 2020-10-02 09:42:35.216 DTC Client socket (1) | Creating socket. | 2020-10-02 09:42:35.489 DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-02 09:42:35.489 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2020-10-02 09:42:35.489 SC Data - All Services | Network connection to server complete. | 2020-10-02 09:42:36.148 SC Data - All Services | Starting socket receive thread. | 2020-10-02 09:42:36.148 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-02 09:42:36.149 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-02 09:42:36.322 SC Data - All Services | Sending logon request message. | 2020-10-02 09:42:36.322 SC Data - All Services | Received logon response. | 2020-10-02 09:42:37.071 SC Data - All Services | Server Name: SC Realtime Server. | 2020-10-02 09:42:37.071 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-02 09:42:37.071 SC Data - All Services | Successfully connected. | 2020-10-02 09:42:37.071 SC Data - All Services | Trading is not supported. | 2020-10-02 09:42:37.071 SC Data - All Services | Restarting real-time data updates for symbol: XEX20 -> XEX20 | 2020-10-02 09:42:37.071 SC Data - All Services | Received security definition for symbol XEX20 | 2020-10-02 09:42:37.331 HD Request # 9 | Downloading Intraday chart data for XEX20 to the file XEX20.scid. Service: bmf.exchange | 2020-10-02 09:42:42.450 Enabling compression for file: C:\SierraChart2\Data\XEX20.scid. This may take a while. | 2020-10-02 09:42:42.452 HD Request # 9 | Download start date-time: 2020-10-02 09:41:58.000 | 2020-10-02 09:42:42.452 HD Request # 9 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-10-02 09:42:42.453 Socket (2) | Creating socket. | 2020-10-02 09:42:42.454 Socket (2) | New receive buffer size: 5242880 | 2020-10-02 09:42:42.454 Socket (2) | Connecting to IP: 8.18.161.135. | 2020-10-02 09:42:42.454 HD Request # 9 | Setting DTC encoding to Binary VLS | 2020-10-02 09:42:42.754 HD Request # 9 | Sending historical data logon request message. | 2020-10-02 09:42:42.754 HD Request # 9 | Requesting Intraday data. Start date-time: 2020-10-02 09:41:58. Record interval: 0. Symbol: XEX20 | 2020-10-02 09:42:43.410 HD Request # 9 | Decompressing data. | 2020-10-02 09:42:43.567 HD Request # 9 | Receiving Intraday data for XEX20 starting at 2020-10-02 09:41:58.612000 | 2020-10-02 09:42:43.567 Socket (2) | CloseSocket call. | 2020-10-02 09:42:43.568 Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-02 09:42:43.568 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-02 09:42:43.569 Historical data download thread signaled to stop. | 2020-10-02 09:42:43.569 HD Request # 9 | Timestamp of first Intraday data file record written: 2020-10-02 09:41:58.612002 | 2020-10-02 09:42:43.569 HD Request # 9 | Received 2 records from 2020-10-02 09:41:58.612 to 2020-10-02 09:41:58.612 (0.0 seconds) and wrote 2 records for XEX20 | 2020-10-02 09:42:43.569 HD Request # 9 | Completion time: 1s | 2020-10-02 09:42:43.572 HD Request # 9 | Intraday data download complete for XEX20. Unique request ID: 9 | 2020-10-02 09:42:43.572 Removing historical data download ID 9. | 2020-10-02 09:42:43.572 Real-time Intraday chart data file updates started for XEX20 | 2020-10-02 09:42:43.572 Intraday chart data file opened for XEX20 | 2020-10-02 09:42:43.572 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2020-10-02 09:42:43.572 Triggering next historical data download in queue. | 2020-10-02 09:42:43.572 Socket (2) | Socket gracefully closed by remote side. | 2020-10-02 09:42:43.707 Socket (2) | Closed. | 2020-10-02 09:42:43.707 Chart #11 has tagged chart #12 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:43.874 Chart #11 has tagged chart #2 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:43.874 Chart #11 has tagged chart #3 for full recalculation. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:43.874 XEX20 [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:43.890 XEX20 [CBV][M] 50 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:44.345 XEX20 [CBV][M] Renko 5t #3 | Performing a full recalculation because it has been tagged. Chartbook: CCM_BMF_sep2020.Cht | 2020-10-02 09:42:44.364 Date Time Of Last Edit: 2020-10-02 12:47:41
[2020-10-02 18:48:02] |
We do see a problem with BMF data. It appears to be coming in, in 5 second increments. We do not know why this is the case. It is from our data provider. We will ask them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-02 19:03:51] |
Please find another source for BMF/B3 data next month. As we are no longer going to offer this exchange. We have had too much trouble with it from our data provider. We recommend having a look at CQG for this: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-04 16:08:28] |
Thank you, please, let me know after they reply and if I need to take any actions to solve it for now.Please find another source for BMF/B3 data next month.
I took a look at the link you sent, but could not really find BM&F in there. However, looking directly CQG's website I noticed that they offer it. Do you know if this subscription is dealt directly with CQG or I need to go through a broker? If a broker is the option, Do you know if Amp futures offer it? Thank you. |
[2020-10-05 05:56:40] |
Our data providers said they will look into the issue. So that is all we know right now. or I need to go through a broker? If a broker is the option, Do you know if Amp futures offer it?
Yes you do need to definitely go through a broker to access the CQG data. Not sure if AMP supports trading B3. You need to ask them.
[2020-10-08 17:13:41] |
Hi there, Everything has been working fine since you requested your data providers to look into it. I have been searching for other providers for BM&F and, CQG is the one that offers it. I thought it would be possible to use this data in conjunction with Sierra Chart(using my CQG credentials), but they said I would only be able to use BM&F data with their own CQG platform, which would cost more than $500. Would you reconsider continuing offering BM&F, even if it is only its real-time data?(A tradable product would not even be necessary). I see that Sierra Chart is the best platform for the analysis I have been performing for BMF and that would be a huge loss, unfortunately. Date Time Of Last Edit: 2020-10-08 17:15:31
[2020-10-08 20:55:21] |
Ok we will keep BMF/B3 for until about the middle of next year.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-08 20:55:30
[2020-10-08 21:05:48] |
That is great! I really appreciate that. Thanks a lot. |
[2020-10-22 12:14:07] |
Hi there, Would you mind asking Barchart for a data reload. It got disconnected today. Thanks. Date Time Of Last Edit: 2020-10-22 12:14:28
[2020-10-22 15:37:11] |
John - SC Support - Posts: 37891 |
We have restarted the service for B3 on one of our servers, so you should be good now.
[2020-10-22 17:57:40] |
Thank you for restarting the service for B3. The missing data came through, however, real-time data is not coming through, I'm afraid.
[2020-10-22 18:47:04] |
We apologize for this issue. It is now resolved. This time the issue was on our side but it relates to the Barchart symbol cleanup we have been doing, which therefore does relate to a service quality issue that we were resolving with Barchart. If there is any missing data follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-22 19:19:06] |
Not a problem. All good now! Thanks a lot.
