Date/Time: Wed, 12 Feb 2025 04:18:38 +0000
copy chart drawing from Chart# does not work
View Count: 1009
[2020-10-01 10:59:46]
User884550 - Posts: 149
when referencing 2 or more charts from different chartbook, only drawings from 1 chart are displayed.
even if drawings are double extend as lines or double extended rectanges, so issue cant be in chart periods
[2020-10-01 14:55:21]
John - SC Support - Posts: 37891
We are not seeing any problems with this.
Be sure you are entering the information correctly for the charts. Refer to the information here:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
If you are still having a problem, then refer to the information here:
Chart Settings: What to Do If Chart Drawings Do Not Copy
[2020-10-05 06:26:07]
Definitely refer to this section and the following sections:
