Date/Time: Wed, 12 Feb 2025 01:42:04 +0000
Latest version of greencharts
View Count: 507
[2020-10-01 01:23:27] |
User863099 - Posts: 8 |
Is there any reason to update to latest versions? Like security reasons? I am running 2054.
[2020-10-01 07:05:11] |
You should definitely update to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-01 12:30:17] |
If I update to latest version, am I going to have to make new chart books? Definitely update to latest version means I am leaving my computer open to security risks?
[2020-10-01 14:15:54] |
No, your existing Chartbook's will continue to work. The update is going to be mandatory, to the current version effective October 20. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
