Date/Time: Wed, 12 Feb 2025 01:30:37 +0000
How to run a few SierraChart instances on on computer?
View Count: 604
[2020-09-30 20:18:58]
User517260 - Posts: 97
Dear Support, I have 4 licenses and need to run a few SierraChart instances on 4 cores i7 server, but i can run only one instance. server is expensive, I tried to install there virtual machine, but it is restricted there. How I can run a few instances of SC on same server? Thanks.
[2020-09-30 20:57:18]
John - SC Support - Posts: 37891
The additional licenses for Sierra Chart software allow you to run the software concurrently on different computers. If you are going to be running on the same computer, then you do not need to pay for the additional 2 systems.
In order to run additional instances of Sierra Chart, there are two options:
- File >> New Instance
- Separate Installation of Sierra Chart
Refer to the information here for these:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance
[2020-09-30 21:26:26]
Thanks a lot! Best regards!
