Date/Time: Wed, 12 Feb 2025 01:10:48 +0000
Historical chart problem for TSLA
View Count: 608
[2020-09-30 17:06:58]
TeeJay - Posts: 123
this seems not adjusted for the split. Can this please be fixed?
http://www.sierrachart.com/image.php?Image=1601485531736.png
[2020-09-30 17:26:58]
John - SC Support - Posts: 37891
Select Edit >> Delete All Data and Download. This should update the data for the split for you.
[2020-09-30 18:05:00]
TeeJay - Posts: 123
The data was fresh downloaded when I opened the chart, but I did it again. It changed exactly nothing
[2020-09-30 18:10:31]
TeeJay - Posts: 123
but it looks now different, different and still wrong, this is no split adjust
http://www.sierrachart.com/image.php?Image=1601489405455.png
[2020-09-30 19:13:31]
Describe precisely what you did. This is what we see:
http://www.sierrachart.com/image.php?Image=1601492888433.png
[2020-09-30 19:32:55]
TeeJay - Posts: 123
Ok these are the deeps of SC again. I did "Delete Data And Download" but this seems now enough.
I read that John wrote "Delete All Data And Download" I just was not aware that this makes a difference.
Thanks for quick reply
Date Time Of Last Edit: 2020-09-30 19:33:08
