Date/Time: Mon, 25 Nov 2024 12:31:36 +0000
indicating beginning / end of trading time
View Count: 1027
[2014-02-08 19:52:00] |
dominikos - Posts: 106 |
the futures that I trade have a fairly well established pattern with low overnight activity and high activity during the day. Is there a way to set different back ground color for periods of low activity? I use tick charts so this might be a bit tricky but would be tremendously useful when analyzing charts. Thanks, - Dominik |
[2014-02-08 20:40:46] |
Yes. Use the Time Range Highlight study. Instructions to add a study: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-08 20:41:18
[2014-02-08 20:55:17] |
awesome, thank you! This is exactly what I needed.
