Date/Time: Wed, 16 Sep 2026 20:02:23 +0000
PAGO DE DATA
View Count: 795
[2020-09-30 16:17:07]
User456598 - Posts: 27
cordial saludo soporte AMP,
les estoy escribiendo para que por favor el dia de mañana es el primer dia del mes de octubre, por favor se haga la gestión del pago de la data para el mes de octubre, ya que estos ultimos meses he tenido inconvenientes debido a que el pago no se realiza de forma automatica. Agradezco que mañana no tenga ese inconveniente, muchas gracias.
[2020-09-30 16:52:16]
John - SC Support - Posts: 47916
From Google Translate:
kind regards AMP support,
I am writing to you so that tomorrow is the first day of October, please do the management of the payment of the data for the month of October, since these last months I have had problems due to the payment it is not done automatically. I appreciate that tomorrow I do not have that problem, thank you very much.
We are not AMP support, this is Sierra Chart.
Additionally, you are not getting any data from us, it looks like you are getting your data from CQG.
You need to contact AMP for this.
