Date/Time: Wed, 12 Feb 2025 01:13:46 +0000
Trading Futures Spreads
View Count: 709
[2020-09-30 16:00:58] |
The Pipe - Posts: 16 |
With your Denali Feed and order routing service what brokers are you finding that accept futures calendar spread trades correctly? Meaning using and getting correct margin credits at the open of the trade and are using spread price rather than individual legs?
[2020-09-30 18:59:20] |
You need to check with the brokers on this. We do not know. Check with the broker AMP as well. We also recommend using the Sierra Chart Order Routing Service for spread trading: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
