Date/Time: Wed, 12 Feb 2025 04:34:59 +0000
File - Open Trading DOM for Chart to please inherit trade and current quote symbol
View Count: 503
[2020-09-30 14:29:08] |
User100912 - Posts: 104 |
[2020-09-30 19:05:49] |
To do what you want, you need to set the Trade and Current Quote Symbol for the associated symbol in the Global Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-01 01:56:34] |
Is this the correct setting? It is not working for me. I have a GC/MGC chart window and when I open a DOM from the file menu it opens a MGC DOM, not a GC/MGC DOM. |
[2020-10-02 09:54:41] |
We will implement a solution for this in the next release.
