Date/Time: Wed, 12 Feb 2025 01:09:54 +0000
Add usage
View Count: 443
[2020-09-30 13:21:29]
Carol Rutherford - Posts: 66
pAs I got to make a payment it seems different. I see the option option for pay pal and bitcoin which I don't want to use and then I see pay wit Strip.
I clicked on AMEX but then on the next screen it goes to Gpay which I don't want to use. I've never had trouble just using my regular card.
Please advise.
[2020-09-30 13:51:07]
John - SC Support - Posts: 37891
On that "next screen" the GPay is just a button that can take you to GPay if that is the option you want to use. Otherwise, just enter your information in the boxes below that to process your credit card.
We have changed processors for credit cards. We are now using Stripe, which is why it appears different than before. But again, if you just enter the information, it will work just fine.
