Date/Time: Sat, 19 Sep 2026 20:48:39 +0000
Chart issues
View Count: 844
| [2020-09-30 12:41:12] |
| User161549 - Posts: 81 |
I am using a "High/low for a time period study" im using it to calculate the high and lows for the overnight session in the E-mini futures, I have noticed sometimes it plots it correctly and sometimes it doesnt. For example for tonights session I have my start time at 17:00:00 and currently for the high it has 3229 as the most recent high which is where price is currently trading now so it keeps moving but the actual high for the overnight session is up at 3358.25 so not sure what the issue is Curious as to what this might be or what I can do to fix it Thanks |
| [2020-09-30 13:57:53] |
| John - SC Support - Posts: 47939 |
What is your End Time in the study set to? It should be the same as the Evening Session times. Also, if you want to see the lines in the regular hours, then be sure you use the High/Low for Time Period - Extended study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-30 17:38:45] |
Yes I am using the Extended study, I have my end time set to 08:29:59, Im in central time so for me that's right at market open The overnight high I have for todays overnight session (9/30/2020) is 3336.25 in which really I have 3358.25 as the actual high that was put in last night |
| [2020-09-30 17:56:30] |
One other thing to check on is the Line Stop Time. You should really have this set to 16:59:59 in order to ensure that a previous is not trying to be drawn into the current day. It can impact the result you get. If that is not it, then please attach a screenshot so we can see what you are seeing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-30 18:20:34] |
We need to get that chart containing that study only following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-30 18:20:52
| [2020-09-30 19:49:44] |
That appears to have fixed it, I will monitor it for the next couple days just to make sure it stays accurate Thank you for your help |
