Date/Time: Wed, 12 Feb 2025 01:14:22 +0000
Question
View Count: 490
[2020-09-30 11:42:31]
markuz - Posts: 90
can you please help with the following picture, thanks.
imageTom post 9.30.2020.png / V - Attached On 2020-09-30 11:42:21 UTC - Size: 22.15 KB - 187 views
[2020-09-30 15:38:59]
John - SC Support - Posts: 37891
The short answer is that you can't. The data from the Numbers Bars study is not readily available to other studies. The only way to access this data is by creating a custom study using ACSIL. Refer to the following for the introduction to ACSIL:
Advanced Custom Study Interface and Language (ACSIL)
[2020-09-30 19:03:15]
Also refer to:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
