Date/Time: Tue, 04 Nov 2025 18:18:11 +0000
IQFeed not reconnecting
View Count: 2603
[2013-04-17 20:16:46]
JohnL - Posts: 27
Since I've upgraded to v964, I've been been having a lot of problems with IQFeed stopping updating. In order to fix, I have to disconnect and reconnect.
When the problem occurs, the client shows that the status is not connected, but 0 attempted reconnections. Has there been a change to the IQFeed connection? I see something in 932 about IQfeed server disconnections improvements.
I've never really had problems like this before.
[2013-04-18 01:30:20]
It appears that IQ Feed has slightly changed their protocol. There was no mention of this from them. Although they might have mentioned it deep within some technical notes. This has caused one issue and we will see what other problems that might be causing.
[2013-04-18 07:24:22]
FGBL07 - Posts: 19
Since about two days I'm experiencing the same problem: the data stop updating and the IQFeed client pops up without reconnecting. Have to do it manually.
[2013-04-18 16:09:38]
WarriorTrader - Posts: 247
Support, you may want the Message Log window to pop up when the IQ Client gets disconnected from the internet. I am using 961 and there is a text message in the Message Log when this happens, but the status window is green (rightfully so since SC is connected to the IQ Client).
Don't know why the IQ Client is getting disconnected, but most of the time it reconnects on it's own. Sometimes I do have to manually reconnect in the IQFeed Connection Manager.
--WT
On a side note: any time frame when OEC will be using the Fast FIX adapter?
Date Time Of Last Edit: 2013-04-18 16:11:46
