Date/Time: Fri, 02 Oct 2026 19:39:02 +0000
Possible Mouse Scroll Wheel bug with synced charts
View Count: 1074
[2020-09-29 17:18:39]
User400196 - Posts: 2
Dear SC support,
I noticed a small bug or it may be an anomaly with a chart set up that I'm trying to implement. I have several charts stacked up next to each other and vertical scale linking turned on to have price sync across all of them. The power and flexibility of SC continues to blow my mind and the very fact that I can customize a platform in this way is a testimony to what you have created here. I usually move the scale up and down with the hand tool and then the other charts follow. I recently noticed that when I try to use my mouse to scroll up and down it only moves the chart that is active. The other charts that are linked do not follow. Is this intended? Thanks again for your awesome work!
imageScreen Shot 2020-09-29 at 11.05.12 AM.png / V - Attached On 2020-09-29 17:18:03 UTC - Size: 1.06 MB - 374 views
[2022-02-01 04:38:53]
WindfallTrader - Posts: 13
yes, I have failed to make this work. Need help.
Date Time Of Last Edit: 2022-02-01 04:39:37
[2022-02-01 13:56:57]
We will check on this and get this resolved.
[2022-02-02 21:53:44]
Sierra_Chart Engineering - Posts: 25031
This has been solved and will be out in the next release.
[2022-02-02 21:59:49]
May I asked when is the next release scheduled?
[2022-02-02 22:26:29]
j4ytr4der_ - Posts: 947
This has always driven me nuts as I'm a pure scrollwheel user, never ever use or want to use the hand tool. This being fixed would be huge!
[2022-02-03 04:23:19]
Update to the latest prerelease at this time:
Version 2352.
