Date/Time: Mon, 16 Sep 2024 19:08:42 +0000
Highlight a specific price on DOM
View Count: 1044
[2020-09-29 15:31:54] |
Yeager - Posts: 125 |
Hi, Is it possible to highlight a price on the DOM by clicking on it say once to turn it blue, twice to turn it orange, 3 times for yellow? Just as I may have reference prices I would want to track. Or similar functionality? Many thanks T |
[2020-09-29 16:23:33] |
John - SC Support - Posts: 34450 |
There is no functionality of that particular sort. The best option to do something like that would be to use the Horizontal Lines study and set the Price you want to highlight for each line, then set the Subgraph Draw Style to Subgraph Name and Value Labels Only, then turn on the Value Label. You can then change the color of the Subgraph to change the color displayed in the Price Ladder. Refer to the following for the Horizontal Lines study: Horizontal Lines And refer to the following for setting the Subgraph Draw Style: Chart Studies: Subgraphs Tab >> Draw Style And refer to the following for the Value Label: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-29 17:42:08] |
Thanks. Is there a possibility to add this as a feature or study for DOM?
[2020-09-29 18:02:30] |
Not anytime soon.
[2024-02-12 10:52:38] |
pierre.hh - Posts: 6 |
Hi there, imo, this feature is what lacking mainly on the sierradom. For those who needs to highlight bracket indeed on volatile fast instrument, this feature would be a game changer One click to highlight a specific price, and another one click to unhighlight this price. I can imagine guys you are busy but I ve seen this request a few times in here. Regards PA |
