Date/Time: Wed, 12 Feb 2025 01:24:36 +0000
je ne suis pas un professionnelle
View Count: 476
[2020-09-29 15:04:15] |
Utilisateur459167 - Posts: 4 |
pourriez vous corriger car votre programme me considère comme un professionnelle et non un particulier merci pour la rectification
[2020-09-29 16:17:03] |
John - SC Support - Posts: 37891 |
In order to qualify as a Non-Professional, you need to have a trading account. Therefore, when you are filling out the agreements, you need to enter the trading account information. If you do not have a trading account, then the CME charges you as a Professional, and that is why you are being put into that classification. If you do not have a trading account, we recommend using this option for a minimal amount: Easy Solution to CME Funded Trading Account Requirement Also, when you signed the CME Non-Professional Certification, you selected the option No to the question Certified as Non-Professional. You need to select Yes. Please take care of these items and then you will be classified as a Non-Professional. You can access the agreements here: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
