Date/Time: Wed, 12 Feb 2025 01:32:46 +0000
DATA FEED (Gaps in Chart)
View Count: 985
[2020-09-29 14:42:03]
User417422 - Posts: 9
Dear Support,
can ou please check the Data Feed. I have many gaps in my Charts. And the current price doesnt print at the Chart.
imageSierra Charts - 1.png / V - Attached On 2020-09-29 14:41:44 UTC - Size: 188.56 KB - 247 views
imageSierra Charts - 2.png / V - Attached On 2020-09-29 14:41:56 UTC - Size: 188.56 KB - 191 views
[2020-09-29 14:54:31]
John - SC Support - Posts: 37891
You are getting your data from Gain Capital, so we have no control over that data.
The only thing we can tell you to do is to try redownloading the data. Refer to the information here:
[2020-09-29 15:39:11]
the Problem ist not the Data Feed because i try several Data Feed and it have been all the same Problems. This is the answer from Gain Capital ( Sierra Charts is a 3rd party. You would have to contact them if you are having trouble with their platform. OEC Trader is our platform. We can support you if you have issues with that.)
[2020-09-30 08:22:02]
Open a completely new chart for the same symbol. Do you notice any missing data in that chart?
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-09-30 08:22:16
