Date/Time: Wed, 12 Feb 2025 01:34:43 +0000
Range Bars and Scaling
View Count: 588
[2020-09-29 14:39:03]
cfuture - Posts: 68
I am trying to find a way to maintain a display size when changing to various range bar settings.
Eg. If I have a 100 range bar setting and then go to a 500 range bar setting, the range bars increase in size.
Is there a setting to keep the chart from changing and stay a desired size?
Ex. 100 range bar. http://www.sierrachart.com/image.php?Image=1601390129862.png
Ex. 500 range bar. http://www.sierrachart.com/image.php?Image=1601390207169.png
[2020-09-29 14:48:17]
John - SC Support - Posts: 37891
The only thing that comes close to what you are asking for is the use of the Automatic scaling. Refer to the information here:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
