Date/Time: Fri, 02 Oct 2026 11:39:03 +0000
Waiting to reconnect
View Count: 1446
| [2020-09-29 14:24:34] |
| User223281 - Posts: 59 |
Sierrachart wont connect to the data feed. Consistently showing "waiting to reconnect"
| [2020-09-29 14:38:24] |
| John - SC Support - Posts: 48086 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-29 14:45:56] |
Software version: 2159 64-bit | 2020-09-29 08:44:47.247 Safe Mode enabled | 2020-09-29 08:44:47.247 Primary Thread ID: 7128 | 2020-09-29 08:44:47.247 Usage end date: 2020-10-08 | 2020-09-29 08:44:47.247 Enabled for: Advanced Features 2. | 2020-09-29 08:44:47.247 Enabled for: Sierra Chart Historical Data Service. | 2020-09-29 08:44:47.247 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-09-29 08:44:47.247 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-09-29 08:44:47.247 Enabled for exchange2: CME (Trading Account Required) | 2020-09-29 08:44:47.247 Enabled for exchange2: CBOT (Trading Account Required) | 2020-09-29 08:44:47.247 Enabled for exchange2: COMEX (Trading Account Required) | 2020-09-29 08:44:47.247 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-09-29 08:44:47.247 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-09-29 08:44:47.247 Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-09-29 08:44:47.247 Custom symbol settings values: enabled | 2020-09-29 08:44:47.247 Chart Update Interval: 500 | 2020-09-29 08:44:47.247 Intraday Data Storage Time Unit: 0 | 2020-09-29 08:44:47.247 Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-09-29 08:44:47.247 2020-09-29 08:44:47 Local computer time | 2020-09-29 08:44:47.247 2020-09-29 14:44:47 Local computer time in UTC | 2020-09-29 08:44:47.247 2020-09-29 08:44:47 Local computer time in SC Time Zone | 2020-09-29 08:44:47.247 Program path: C:\SierraChart\ | 2020-09-29 08:44:47.247 Data Files path: C:\SierraChart\Data\ | 2020-09-29 08:44:47.247 OS Version Number: 10.0 | 2020-09-29 08:44:47.249 Locale Setting: C | 2020-09-29 08:44:47.249 DLLs: DOM.dll, GomMPPro.dll, GomMPPro_2151.dll, GomMPPro_2151_64.dll, GomMPPro_64.dll, GomOrderFlowPro.dll, GomOrderFlowPro_2151.dll, GomOrderFlowPro_2151_64.dll, GomOrderFlowPro_64.dll, OFA Bars (by Zdislav)_64.dll, rbcc_64 (1).dll, rbcc_footprint_64 (1).dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free (2020).dll, zyp sierra free (2020)_64.dll, zyp sierra free.dll, zyp sierra free_64.dll | 2020-09-29 08:44:47.249 Allowed protected custom studies: GomOrderFlowPro, zyp_download_free | 2020-09-29 08:44:47.249 File >> Disconnect selected. | 2020-09-29 08:45:06.817 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:06.817 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:06.817 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:09.303 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:09.304 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:09.304 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:09.304 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:09.304 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:09.311 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:09.311 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:09.311 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:10.343 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:10.344 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:10.344 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:10.345 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:10.345 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:10.374 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:10.374 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:10.374 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:11.390 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:11.392 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:11.392 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:11.392 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:11.392 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:11.420 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:11.420 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:11.420 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:12.421 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:12.422 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:12.422 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:12.422 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:12.422 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:12.437 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:12.437 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:12.437 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:13.453 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:13.454 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:13.454 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:13.454 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:13.454 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:13.468 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:13.468 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:13.468 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:14.483 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:14.485 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:14.485 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:14.485 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:14.485 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:14.499 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:14.499 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:14.499 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:15.499 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:15.500 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:15.500 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:15.500 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:15.500 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:15.515 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:15.515 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:15.515 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:16.546 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:16.547 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:16.653 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:16.653 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:16.653 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:16.736 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:16.736 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:16.736 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:17.749 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:17.750 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:17.750 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:17.750 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:17.750 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:17.765 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:17.765 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:17.765 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:18.780 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:18.781 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:18.781 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:18.781 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:18.781 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:18.796 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:18.796 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:18.796 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:19.812 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:19.813 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:19.813 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:19.813 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:19.813 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:19.827 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:19.827 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:19.827 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:20.828 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:20.828 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:20.828 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:20.828 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:20.828 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:20.843 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:20.843 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:20.843 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:21.859 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:21.860 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:21.860 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:21.860 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:21.860 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:21.874 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:21.874 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:21.874 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:22.890 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:22.891 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:22.891 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:22.891 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:22.891 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:22.921 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:22.921 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:22.921 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:23.937 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:23.938 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:23.938 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:23.938 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:23.938 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:23.952 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:23.953 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:23.953 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:24.952 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:24.953 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:24.953 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:24.953 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:24.953 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:24.968 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:24.968 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:24.968 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:25.983 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:25.984 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:25.984 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:25.984 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:25.984 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:26.014 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:26.014 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:26.014 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:27.030 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:27.031 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:27.031 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:27.032 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:27.032 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:27.046 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:27.046 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:27.046 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:28.047 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:28.048 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:28.048 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:28.048 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:28.048 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:28.062 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:28.062 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:28.062 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:29.078 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:29.079 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:29.079 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:29.079 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:29.079 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:29.093 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:29.093 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:29.093 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:30.109 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:30.111 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:30.111 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:30.111 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:30.111 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:30.124 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:30.124 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:30.125 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:31.139 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:31.140 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:31.140 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:31.140 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:31.140 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:31.155 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:31.155 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:31.155 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:32.155 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:32.156 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:32.156 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:32.157 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:32.157 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:32.186 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:32.186 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:32.186 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:33.187 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:33.188 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:33.188 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:33.188 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:33.188 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:33.202 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:33.202 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:33.202 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:34.219 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:34.220 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:34.220 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:34.220 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:34.220 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:34.233 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:34.233 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:34.233 SC Futures Order Routing/Data | Connecting to the server futurestrading4.sierracharts.com. Port 11098 | 2020-09-29 08:45:35.249 Error getting address info for futurestrading4.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:35.251 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:35.251 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:35.251 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:35.251 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:35.280 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:35.280 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:35.280 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-09-29 08:45:36.265 Error getting address info for futurestrading2.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:36.266 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:36.267 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:36.267 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:36.267 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:36.295 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:36.295 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:36.295 SC Futures Order Routing/Data | Connecting to the server futurestrading1.sierracharts.com. Port 11098 | 2020-09-29 08:45:37.296 Error getting address info for futurestrading1.sierracharts.com. Windows error code 11001: No such host is known. | 2020-09-29 08:45:37.297 DTC Client socket (1) | CloseSocket call. | 2020-09-29 08:45:37.297 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-09-29 08:45:37.297 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:37.297 DTC Client socket (0) | CloseSocket call. | 2020-09-29 08:45:37.312 SC Futures Order Routing/Data | Disconnected. | 2020-09-29 08:45:37.312 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-09-29 08:45:37.312 |
| [2020-09-29 15:01:57] |
The first thing we want you to do is to reboot your system. This in combination with the other problem make us think something is not quite right with your system today. But, if you continue to have this issue after a reboot, then refer to the following documentation for resolutions: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-29 15:16:13] |
ok, i rebooted. Now a new issue occurs where it says the SC Futures and Order Routing/Data is not enabled on package.. It does seem to connect to SC Data - All services though
| [2020-09-29 16:19:29] |
This time we need you to exit from Sierra Chart and then follow these instructions to start Sierra Chart with a Forced Login: Sierra Chart - Software Login Instructions: Forced Login This should take care of it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-29 19:49:18] |
Looks like this was caused by a firewall issue on your side. Also instead of restarting doing the following may have accomplish the same thing: ipconfig /flushdns on the Windows command line.
