Date/Time: Wed, 12 Feb 2025 01:43:21 +0000
Reference Range Data - Is this possible?
View Count: 540
[2020-09-29 09:32:12] |
User403758 - Posts: 25 |
Hello, I like to use alerts with ranges, e.g. =SG1[0:-10] Now I need to put in something like =SG1[0:"FIRST Bar of SESSION"] Is this somehow possible? (I know it is possible via Spreadsheet but I don't use Spreadsheets) Thanks! :) |
[2020-09-29 14:32:24] |
John - SC Support - Posts: 37891 |
No, this is not supported. Nor is there a direct way to specify the first bar of a session within the simple alerts.
[2020-09-29 15:33:59] |
Ok, thanks for your answer, so I can stop searching for a way :/
