Date/Time: Wed, 12 Feb 2025 01:28:32 +0000
Price Retracement (fibs) values to small to read on chart in Mac Boot Camp
View Count: 665
[2020-09-29 03:21:05] |
BKP_ATL - Posts: 12 |
I'm using Sierra in Boot Camp on my Macbook Pro. I've already dealt with text size, etc, on the charts by using Chart/Graphic Settings-Chart and going into fonts. But no font option in there affects the size of the label for tools on my charts. Searched and can't find anything. Thanks for the help. See attached screenshot.
[2020-09-29 04:00:38] |
Kiwi - Posts: 375 |
From an earlier post: The text on the Fibonacci Fan is controlled through the Font selection for Chart Text. So it can be changed, but this will also change all the other text in the chart, including the scales. To change this setting, refer to the following documentation: Graphics Settings: Fonts and Text Appearance Most likely you were trying to change this on the Chart >> Graphics Settings - Chart while the option Use Global Graphics Settings Instead of These Settings was enabled. For information on this setting, refer to this documentation: Graphics Settings: Use Global Graphics Settings Instead of These Settings Also refer to: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) |
[2020-09-29 04:28:13] |
Thanks! Your first and second suggestion I had done correctly but no change. The third option of "Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) and going into Global Settings/Tool Settings and changing the font in "Global Chart Drawing Font" is what did it.
