Date/Time: Sat, 13 Sep 2025 04:59:44 +0000
[User Discussion] - Access to old Support Board
View Count: 885
[2020-09-28 23:04:15] |
Kiwi - Posts: 375 |
Is this still possible? Can I please get a link. One of your users is using an old function T1 from a dll kiwi_test around 2012 I can't find the old source but will have published it in the forum. |
[2020-09-28 23:08:39] |
Kiwi - Posts: 375 |
Actually its should be in kiwi12.cpp kiwi custom study T1 is missing |
[2020-09-29 04:12:22] |
Ackin - Posts: 1865 |
Look: Kiwi Resync Study - Memory leak? | Post: 174469 |
[2020-09-29 04:29:44] |
Kiwi - Posts: 375 |
Found it in another thread ... I was looking for a study called T1 but TI was the graph name & the study was TInt. Will fix a file to compile with Sierra Chart 2175 and publish here. Date Time Of Last Edit: 2020-09-29 04:47:26
[2020-09-29 04:41:45] |
Kiwi - Posts: 375 |
So I've attached the code file (.cpp) and the dll compiled with Sierra Chart 2175 here. I see I was in my 'compact is better' phase back in 2012. The code was just: #include "sierrachart.h"
SCDLLName("* Kiwi 12 Recovery *") /*==========================================================================*/ SCSFExport scsf_RecalcChart(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Recalc"; sc.StudyDescription = "Recalc Chart every x secs based on real time"; sc.Subgraph[0].Name = "Strobe"; sc.Subgraph[1].Name = "Time"; sc.Subgraph[0].DrawStyle=DRAWSTYLE_IGNORE; sc.Subgraph[1].DrawStyle=DRAWSTYLE_IGNORE; sc.Input[0].Name="Seconds between recalcs"; sc.Input[0].SetInt(60); sc.Input[1].Name="Also reload chart data"; sc.Input[1].SetYesNo(0); sc.UpdateAlways=1; return; } if (sc.CurrentSystemDateTime.GetTime() % sc.Input[0].GetInt() == 0) { if (sc.Subgraph[0][sc.ArraySize-1] < 999660) { sc.Subgraph[0][sc.ArraySize-1] = 999666; sc.Subgraph[1][sc.ArraySize-1] = sc.CurrentSystemDateTime.GetTime(); sc.FlagFullRecalculate = 1; if (sc.Input[1].GetYesNo()) sc.FlagToReloadChartData = 1; } else sc.Subgraph[0][sc.ArraySize-1] = 0; } } /*==========================================================================*/ SCSFExport scsf_TInt(SCStudyGraphRef sc) { if (sc.SetDefaults) { sc.GraphName="TI"; sc.StudyDescription="Tick Interpretter"; sc.Subgraph[0].Name="TI+"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_BAR; sc.Subgraph[1].Name="TI-"; sc.Subgraph[1].DrawStyle = DRAWSTYLE_BAR; sc.Subgraph[6].Name="Up Colour"; sc.Subgraph[7].Name="Dn Colour"; sc.Subgraph[8].Name="Neutral Colour"; sc.Input[2].Name="Cut Off 1"; sc.Input[2].SetInt(500); sc.Input[3].Name="Cut Off 2"; sc.Input[3].SetInt(1100); sc.DrawZeros=0; return; } int& cutoff1 = sc.Input[2].IntValue; int& cutoff2 = sc.Input[3].IntValue; SCSubgraphRef value1 = sc.Subgraph[0], value2 = sc.Subgraph[1], answer = sc.Subgraph[5]; for ( int i=sc.UpdateStartIndex; i < sc.ArraySize; i++) { float medianprice = (sc.High[i] + sc.Low[i]) / 2; answer[i] = 0; if(sc.High[i] > cutoff1) answer[i] = answer[i] + (sc.High[i] - cutoff1); if(medianprice > cutoff1) answer[i] = answer[i] + (medianprice - cutoff1); if(sc.High[i] > cutoff2) answer[i] = answer[i] + 2.0*(sc.High[i] - cutoff2); if(sc.Low[i] < -cutoff1) answer[i] = answer[i] - (-cutoff1 - sc.Low[i]); if(medianprice < -cutoff1) answer[i] = answer[i] - (-cutoff1 - medianprice); if(sc.Low[i] < -cutoff2) answer[i] = answer[i] - 2.0*(-cutoff2 - sc.Low[i]); value1[i] = (answer[i-1] + 2.0*answer[i]) / 3.0; //value2[i] = (answer[i-2] + 2.0*answer[i-1]) / 3.0; if(value1[i] > 0) sc.Subgraph[0].DataColor[i] = sc.Subgraph[1].DataColor[i] = sc.Subgraph[6].PrimaryColor; else if(value1[i] < 0) sc.Subgraph[0].DataColor[i] = sc.Subgraph[1].DataColor[i] = sc.Subgraph[7].PrimaryColor; else sc.Subgraph[0].DataColor[i] = sc.Subgraph[1].DataColor[i] = sc.Subgraph[8].PrimaryColor; } } |
[2020-10-01 09:29:18] |
User90125 - Posts: 715 |
Thanks for this, Kiwi. And especially providing the updated raw .cpp source code as well :) Now if I could only figure out how to make a study that automatically recalculates and/or reloads a chart when a Session Time boundary is crossed..... |
[2020-10-01 12:01:02] |
Kiwi - Posts: 375 |
Assuming you mean in real time ... something like this which is testing for start of day (if my functions are right). /*==========================================================================*/
SCSFExport scsf_RecalcChartEOD(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Recalc on Day"; sc.StudyDescription = "Recalc Chart every day"; sc.Subgraph[0].Name = "Strobe"; sc.Subgraph[1].Name = "Time"; sc.Subgraph[0].DrawStyle=DRAWSTYLE_IGNORE; sc.Subgraph[1].DrawStyle=DRAWSTYLE_IGNORE; sc.Input[0].Name="Seconds between recalcs"; sc.Input[0].SetInt(60); sc.Input[1].Name="Also reload chart data"; sc.Input[1].SetYesNo(0); sc.UpdateAlways=1; return; } int signal_bar = -1; for (int pos = 0; pos < sc.ArraySize; pos++) { // only for last bar, then new day, then only once in the bar if (pos == sc.ArraySize - 1) { if (sc.BaseDateTimeIn[pos].GetDate() > sc.BaseDateTimeIn[pos-1].GetDate()) { if (pos != signal_bar) { sc.FlagFullRecalculate = 1; signal_bar = pos; } } else signal_bar = -1; } } } |
[2020-10-02 00:08:19] |
Kiwi - Posts: 375 |
I thought about it and that's not terribly good code. Here's a better version ... and the start of a new kiwi's stuff, kiwi_20. This one permits you to select 3 times (just duplicate a time or use an untraded time if you don't need 3). Modifying it should be easy if needed 🙂 SCSFExport scsf_RecalcChartAtTimes(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "RecalcAtTimes"; sc.StudyDescription = "Recalc At Specified Times"; sc.GraphRegion = 0; sc.Subgraph[0].Name = "Strobe"; sc.Subgraph[1].Name = "dbg 0"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_IGNORE; sc.Subgraph[1].DrawStyle = DRAWSTYLE_IGNORE; sc.Input[1].Name="Also reload chart data"; sc.Input[1].SetYesNo(0); sc.Input[2].Name = "Time to Recalc"; sc.Input[2].ValueType = TIME_VALUE; sc.Input[3].Name = "Time to Recalc"; sc.Input[3].ValueType = TIME_VALUE; sc.Input[4].Name = "Time to Recalc"; sc.Input[4].ValueType = TIME_VALUE; return; } int& bar_is_tested = sc.GetPersistentIntFast(0); // This will test if this bar has been checked and if not // it will test if the bar includes one of the times // and if it does: recalculate and reload if chosen if (sc.ArraySize != bar_is_tested) { bar_is_tested = sc.ArraySize; int this_ = sc.BaseDateTimeIn[sc.ArraySize-1].GetTime(); int next_ = sc.BaseDateTimeIn[sc.ArraySize-1].GetTime() + sc.SecondsPerBar; if ((sc.Input[2].GetTime() >= this_ && sc.Input[2].GetTime() < next_) || (sc.Input[3].GetTime() >= this_ && sc.Input[3].GetTime() < next_) || (sc.Input[4].GetTime() >= this_ && sc.Input[4].GetTime() < next_)) { sc.Subgraph[0][sc.ArraySize-1] = this_; sc.FlagFullRecalculate = 1; if (sc.Input[1].GetYesNo()) sc.FlagToReloadChartData = 1; } } } |
