Date/Time: Wed, 12 Feb 2025 01:26:09 +0000
Attached Orders Misinterpretation ?
View Count: 619
[2020-09-28 21:23:01]
User181601 - Posts: 25
HI, I was testing the attached orders on demo and i was trying to achieve the following:
These are just inputs i tried, to check if it worked the way i was thinking_
1_I wanted the Stop to move to BE after 6 ticks Price advance (Step 1) (Offset in Ticks Triggered)
2_Then after a further 6 Ticks Price advance (Step 2) (Offset in Ticks Triggered)
i wanted the Stop to be moved 4 Ticks from/past the BE
After Step 1 happened, i was expecting Step 2 to be activated
but it didnt work, as i saw that the (Step 2 Inputs/ 6-4) came in before the (Step 1 Inputs/6-0))
Obviously i must have failed in my interpretation of the terminology of the instructions
and wonder if it is possible in simple words to describe what to do in order to achieve
the above 2 Step
I have been on it 3 days and i don't seem to get it right_
I don't try these settings on replay chart, as it replays me past taken trades, and it gets confusing,
but i try them when the market it is open
so i need to wait until it happens
Help appreciated
Many Thanks
imagestep 1 and 2 pics show.jpg / V - Attached On 2020-09-28 21:22:32 UTC - Size: 404.83 KB - 224 views
[2020-09-29 06:53:12]
Step 2 needs to use 12 for the Trigger Offset.
[2020-09-29 09:09:24]
Thank you sir, let me try this one then ...
