Date/Time: Wed, 12 Feb 2025 01:22:05 +0000
Question about CPU performance
View Count: 493
[2020-09-28 17:12:03] |
User542430 - Posts: 50 |
I use a large number of Alert Studies on my charts. Under Study Settings, does unchecking the Include in Study Summary box and the Include in Spreadsheet box, as well as unchecking the Enabled box under Alerts cause any noticeable performance improvement? My computer runs very hot with SC running, I am looking for any ways I can to reduce CPU/GPU load. |
[2020-09-28 19:26:54] |
Those settings in and of themselves do not change performance in any way unless you are using the Study Summary, the Spreadsheet Study or alerts. And really it is only the Spreadsheet study is where there would be any potential performance improvement by minimizing the amount of data transferred in and out. And ultimately, you should just try and see for yourself what performance improvement there is because really from our position, we cannot answer this question. You have to see for yourself because you are doing what you are doing. It is impossible for us to make any predictions or estimates on what the outcome would be based upon what you are doing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-28 22:48:17
