Date/Time: Wed, 27 Nov 2024 04:52:23 +0000
volume by price study
View Count: 1545
[2020-09-28 16:16:20] |
szdaniel1994 - Posts: 18 |
Hi guys! Thanks for the great platform. I have a problem which I tried to research but havent found an answer yet. What I’m trying to do is to have a volume by price study on the right side calculated from all the volume displayed on the chart. Additionally another volume by study price study which uses only the last day’s volume. Plus what I really want is to display in a way where the volume profiles are directly comparable (i.e are on the same scale). This is how set it up so far: Put two seperate volume by price study to a 60 min intraday chart. volume graph period type = visible bars volume graph period type = Multiple profiles based on fixed time Time period type for fixed time: day time period length for fixed time: 1 Additionally Right align volume bars = yes volume profile bars length relative to all visible profiles = yes But it seems not working. So still see that the length of the volume profile is based on the Maximum volume bar width type and the Maximum volume bar width percentage parameters. Could you please advise how can I setup the studies such that the volume profiles are directly comparable ? (for example lets say if the point of control of the two volume profiles represents 100 and 500 units of volume then on the chart I would like to see the longer horizontal bar exactly 5 times long compared to the small) Thank you |
[2020-09-28 19:15:55] |
Could you please advise how can I setup the studies such that the volume profiles are directly comparable ? This is not supported for different instances of the Volume by Price study.
[2020-10-01 07:19:24] |
Is there a way to use the volume value corresponding to the point of control in another study? So for example given a volume by price study and the point of control of it, shows a specific price level, and I would like to use the volume of that price level in a calculation. Thanks |
[2020-10-05 15:53:09] |
Refer to: Volume By Price Study: Programmatically Accessing Volume at Price Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-09-19 14:13:39] |
User321002 - Posts: 3 |
Can you provide the code/link for the Volume by Price study. It is not available in any of the custom studies that are shipped in Sierra Charts.
[2023-09-19 16:56:22] |
Sierra_Chart Engineering - Posts: 17190 |
This is not available. Refer to: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
