Date/Time: Wed, 12 Feb 2025 01:25:34 +0000
Looking to increase market depth
View Count: 548
[2020-09-28 16:12:19]
Rexz - Posts: 22
Currently I am using the level 5 service package of sierra chart through AMP using CQG for the data. This is currently a monthly cost of $36 ($25 for Sierra Charts and $11 for CME). If I want more market depth, then the options I have through AMP are Rithmic (an extra $20/month) or TT (also $20/month). So in total the cost will jump to $55/month (less $1 CQG admin fee). Is this the only 2 options I have? I noticed a post about changing routing through TT that you offered but I didn't see the benefit if that is also $20. Is there any way to reduce those fees or am I stuck with a minimum of $55/month?
Sam
[2020-09-28 20:13:42]
You will want to use the Sierra Chart order routing service:
Sierra Chart / Trading Technologies Futures Order Routing Service
We assume, that when they are referencing TT, they are actually referring to the Sierra Chart Futures Order Routing Service, which would be an additional $20.00 USD per month for the Denali Exchange Data Feed which gives you extended/full market depth data (the exchange fees are approximately the same between vendors).
You could also get the data from us through the Denali Exchange Data Feed, and stay with CQG for your trading service, then the cost is actually $25.00 USD per month (plus the exchange fees).
Therefore, from what you are stating, we do not see anything cheaper than $55.00 USD per month.
We do not recommend using Rithmic as we have discontinued support for Rithmic.
