Date/Time: Wed, 16 Sep 2026 10:17:12 +0000
[User Discussion] - How to have a study starting from a clicked location on the chart?
View Count: 1296
[2020-09-28 12:28:58]
mbilyanov - Posts: 62
I’m trying to have a left click, select a menu item and run a study from the clicked bar onwards.
I’m aware of this being a bit complex, but I have seen the examples with point-and-click and menu related operations.
The only thing I would like to know is: Do we turn off auto looping and loop ourselves from the starting bar index to the most recent bar or is there a different approach that I’m missing.
I mean, to make a study start from a specific bar index?
[2020-11-09 12:50:26]
maxima120 - Posts: 168
it sounds impossible for SC.
where did you see it?
Date Time Of Last Edit: 2020-11-09 12:50:37
[2020-11-09 12:55:10]
I have already done it, so it is possible :)
Many custom studies are using this, where you need to click on the chart and run a study from the clicked location forward.
[2020-11-09 12:57:42]
kudos to you :)
[2020-11-09 12:58:43]
Ackin - Posts: 1865
this is not possible, studies are initialized immediately .... but calculation is possible from a specific bar or datastartindex
The error is not in Sierrachart but elsewhere. Sierrachart together with c ++ but also Spreadsheets has unlimited possibilities.
for example user contributed studies ....anchor vwap
[2020-11-09 15:30:34]
Correct!
Manual looping from clicked index to the most recent index.
[2020-12-06 08:53:17]
User139950 - Posts: 4
This is my resettable version of the Cumulative Delta Bars Study:
SCSFExport scsf_CumulativeDeltaBarsTickVolumeReset(SCStudyInterfaceRef sc)
  SCSubgraphRef Open = sc.Subgraph[SC_OPEN];
  SCSubgraphRef High = sc.Subgraph[SC_HIGH];
  SCSubgraphRef Low = sc.Subgraph[SC_LOW];
  SCSubgraphRef Close = sc.Subgraph[SC_LAST];
  SCSubgraphRef OHLCAvg = sc.Subgraph[SC_OHLC_AVG];
  SCSubgraphRef HLCAvg = sc.Subgraph[SC_HLC_AVG];
  SCSubgraphRef HLAvg = sc.Subgraph[SC_HL_AVG];
  SCInputRef ResetAtSessionStart = sc.Input[0];
  SCInputRef ResetAtBothSessionStarts = sc.Input[1];
  int& ResetID = sc.GetPersistentInt(1);
  int& MenuID_Set = sc.GetPersistentInt(2);
  int& MenuID_Clear = sc.GetPersistentInt(3);
  if (sc.SetDefaults)
    sc.GraphName = "Resettable Cumulative Delta Bars - Up/Down Tick Volume";
    sc.MaintainAdditionalChartDataArrays = 1;
    sc.AutoLoop = 0;//Manual looping
    sc.ValueFormat = 0;
    sc.GraphDrawType = GDT_CANDLESTICK;
    Open.Name = "Open";
    Open.DrawStyle = DRAWSTYLE_LINE;
    Open.PrimaryColor = RGB(0,255,0);
    Open.SecondaryColor = RGB(0,255,0);
    Open.SecondaryColorUsed = true;
    Open.DrawZeros = true;
    High.Name = "High";
    High.DrawStyle = DRAWSTYLE_LINE;
    High.PrimaryColor = RGB(0,128,0);
    High.DrawZeros = true;
    Low.Name = "Low";
    Low.DrawStyle = DRAWSTYLE_LINE;
    Low.PrimaryColor = RGB(255,0,0);
    Low.SecondaryColor = RGB(255,0,0);
    Low.SecondaryColorUsed = true;
    Low.DrawZeros = true;
    Close.Name = "Close";
    Close.DrawStyle = DRAWSTYLE_LINE;
    Close.PrimaryColor = RGB(128,0,0);
    Close.DrawZeros = true;
    OHLCAvg.Name = "OHLC Avg";
    OHLCAvg.DrawStyle = DRAWSTYLE_IGNORE;
    OHLCAvg.PrimaryColor = COLOR_GREEN;
    OHLCAvg.DrawZeros = true;
    HLCAvg.Name = "HLC Avg";
    HLAvg.Name = "HL Avg";
    HLAvg.DrawStyle = DRAWSTYLE_IGNORE;
    HLAvg.PrimaryColor = COLOR_GREEN;
    HLAvg.DrawZeros = true;
    ResetAtSessionStart.Name = "Reset at Start of Trading Day";
    ResetAtSessionStart.SetYesNo(true);
    ResetAtBothSessionStarts.Name = "Reset at Both Session Start Times";
    ResetAtBothSessionStarts.SetYesNo(false);
    ResetID = -1;
    MenuID_Set = -1;
    MenuID_Clear = -1;
    return;
  // add the menu command when study is added
  if (sc.UpdateStartIndex == 0)
    MenuID_Set = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Set Delta Reset");
    MenuID_Clear = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Clear Delta Reset");
    if (MenuID_Set < 0 || MenuID_Clear < 0)
      sc.AddMessageToLog("Add ACS Chart Shortcut Menu Item failed", 1);
  // remove the menu command when study is removed
  if (sc.LastCallToFunction)
    sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, MenuID_Set);
    sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, MenuID_Clear);
  // receive menu event
  if (sc.MenuEventID != 0 && sc.MenuEventID == MenuID_Set)
    // get idx for resetting
    ResetID = sc.ActiveToolIndex;
    // initiate recalculation
    sc.UpdateStartIndex = 0;
  if (sc.MenuEventID != 0 && sc.MenuEventID == MenuID_Clear)
    // clear idx for resetting
    ResetID = -1;
  for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++)
    bool Reset = false;
    if (Index == 0 || Index == ResetID)
      Reset = true;
    else if (ResetAtBothSessionStarts.GetYesNo() != 0)
      SCDateTime PriorStartOfPeriod = sc.GetStartOfPeriodForDateTime(sc.BaseDateTimeIn[Index - 1], TIME_PERIOD_LENGTH_UNIT_DAYS, 1, 0, 1);
      SCDateTime StartOfPeriod = sc.GetStartOfPeriodForDateTime(sc.BaseDateTimeIn[Index], TIME_PERIOD_LENGTH_UNIT_DAYS, 1, 0, 1);
      if (StartOfPeriod != PriorStartOfPeriod)
        Reset = true;
    else if (ResetAtSessionStart.GetYesNo() != 0)
      SCDateTime PriorStartOfPeriod = sc.GetStartOfPeriodForDateTime(sc.BaseDateTimeIn[Index - 1], TIME_PERIOD_LENGTH_UNIT_DAYS, 1, 0, 0);
      SCDateTime StartOfPeriod = sc.GetStartOfPeriodForDateTime(sc.BaseDateTimeIn[Index], TIME_PERIOD_LENGTH_UNIT_DAYS, 1, 0, 0);
        Reset = true;
    sc.CumulativeDeltaTickVolume(sc.BaseDataIn, Close, Index, Reset);
    Open[Index] = Close.Arrays[0][Index];
    High[Index] = Close.Arrays[1][Index];
    Low[Index] = Close.Arrays[2][Index];
    sc.CalculateOHLCAverages(Index);
