Date/Time: Sat, 12 Sep 2026 22:17:07 +0000
[Programming Help] - ACSIL function for sorting values?
View Count: 4106
[2020-09-28 08:56:53]
User267701 - Posts: 66
Greetings,
does ACSIL already offer a sc.function for arranging values in an array or do i have to implement a c++ sorting algo like these?:
https://www.softwaretestinghelp.com/sorting-techniques-in-cpp/
Problem for me is, that dont understand a single one of these algos...no chance. Its completely above my skills.
Regards
Date Time Of Last Edit: 2020-09-28 12:36:38
[2020-09-28 12:07:57]
Kiwi - Posts: 375
You shouldn't need to understand sorting algorithms. Just use the standard library functions:
https://en.cppreference.com/w/cpp/algorithm/sort
and read this
Sorting arrays in ACSIL
Date Time Of Last Edit: 2020-09-28 12:09:10
[2020-10-09 01:18:07]
bekitz - Posts: 26
I am also interested in this functionality.
I read both links in post #2.
Using both examples in the links & for simplicity sake, if I wanted to sort all of the closing prices with the following code attempt:
SCSubgraphRef Closes = sc.Subgraph[0];
SCSubgraphRef Sort_Closes = sc.Subgraph[1];
//ignore default section;
Closes[sc.Index] = sc.Close[sc.Index];
Sort_Closes[sc.Index] = std::sort(Closes.begin(), Closes.end());
I get errors saying that 'begin' & 'end' are not part of the subgraph struct, etc.
Any assistance is appreciated.
[2020-10-09 05:52:06]
Ackin - Posts: 1865
Sierrachart example
SCSFExport scsf_StochasticPercentile(SCStudyInterfaceRef sc)
  SCSubgraphRef Subgraph_Stochastic = sc.Subgraph[0];
  SCSubgraphRef Subgraph_StochasticAverage = sc.Subgraph[1];
  SCSubgraphRef Subgraph_Line1 = sc.Subgraph[2];
  SCSubgraphRef Subgraph_Line2 = sc.Subgraph[3];
  SCInputRef Input_Data = sc.Input[0];
  SCInputRef Input_StochasticLength = sc.Input[1];
  SCInputRef Input_MovingAverageLength = sc.Input[2];
  SCInputRef Input_Line1Value = sc.Input[3];
  SCInputRef Input_Line2Value = sc.Input[4];
  if (sc.SetDefaults)
    sc.GraphName = "Stochastic - Percentile";
    sc.ValueFormat = 2;
    Subgraph_Stochastic.Name = "Stochastic%";
    Subgraph_Stochastic.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_Stochastic.PrimaryColor = RGB(0,255,0);
    Subgraph_Stochastic.DrawZeros = true;
    Subgraph_StochasticAverage.Name = "Average";
    Subgraph_StochasticAverage.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_StochasticAverage.PrimaryColor = RGB(255, 127, 0);
    Subgraph_StochasticAverage.DrawZeros = true;
    Subgraph_Line1.Name = "Line1";
    Subgraph_Line1.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_Line1.PrimaryColor = RGB(255, 255, 0);
    Subgraph_Line1.DrawZeros = true;
    Subgraph_Line2.Name = "Line2";
    Subgraph_Line2.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_Line2.PrimaryColor = RGB(0, 0, 255);
    Subgraph_Line2.DrawZeros = true;
    Input_Data.Name = "Input Data";
    Input_Data.SetInputDataIndex(SC_LAST);
    Input_StochasticLength.Name = "Length";
    Input_StochasticLength.SetInt(10);
    Input_StochasticLength.SetIntLimits(1,MAX_STUDY_LENGTH);
    Input_MovingAverageLength.Name = "Moving Average Length";
    Input_MovingAverageLength.SetInt(10);
    Input_MovingAverageLength.SetIntLimits(1, MAX_STUDY_LENGTH);
    Input_Line1Value.Name = "Line 1 Value";
    Input_Line1Value.SetFloat(20);
    Input_Line2Value.Name = "Line 2 Value";
    Input_Line2Value.SetFloat(80);
    sc.AutoLoop = false;
    return;
  std::vector<float> AscendingValues;
  SCFloatArrayRef DataArray = sc.BaseData[Input_Data.GetInputDataIndex()];
  sc.DataStartIndex = Input_StochasticLength.GetInt() - 1;
  for (int CurrentIndex = sc.UpdateStartIndex; CurrentIndex < sc.ArraySize; CurrentIndex++)
    AscendingValues.clear();
    int FirstIndex = CurrentIndex - Input_StochasticLength.GetInt() + 1;
    for (int BarIndex = FirstIndex; BarIndex <= CurrentIndex; BarIndex++)
      AscendingValues.push_back(DataArray[BarIndex]);
    std::sort(AscendingValues.begin(), AscendingValues.end());
    float CurrentPrice = DataArray[CurrentIndex];
    int AscendingValuesSize = static_cast<int>(AscendingValues.size());
    int AscendingValuesIndex = 0;
    for(; AscendingValuesIndex < AscendingValuesSize; AscendingValuesIndex++)
      if (CurrentPrice == AscendingValues[AscendingValuesIndex])
        break;
      if (AscendingValuesIndex == AscendingValuesSize - 1)
        break;
    Subgraph_Stochastic[CurrentIndex] = 100.0f*AscendingValuesIndex/(Input_StochasticLength.GetInt() - 1);
    sc.SimpleMovAvg(Subgraph_Stochastic, Subgraph_StochasticAverage, CurrentIndex, Input_MovingAverageLength.GetInt());
    Subgraph_Line1[CurrentIndex] = Input_Line1Value.GetFloat();
    Subgraph_Line2[CurrentIndex] = Input_Line2Value.GetFloat();
  return;
