Date/Time: Mon, 25 Nov 2024 12:39:39 +0000
[User Discussion] - 50% retracement
View Count: 1442
[2014-02-08 00:37:58]
lou_diamonds - Posts: 39
What's the best way to do a half way point between the high of a specific bar & the low of a specific bar? Is there a way for me to do this via point & click?
For example, if the stock is trending up & the low point is 50 and the high point is 100, how do I get it to calculate 75? Ideally, I'd like to point the mouse at the bar with the low of 50 and drag it to the bar with the high of 100.
[2014-02-08 00:42:10]
Tonkadad - Posts: 235
You could use the "Price retracement tool" and set it up how you need it, put it on a toolbar for easy access.
[2014-02-08 02:10:23]
THANKS! This is exactly what I needed!
