Date/Time: Wed, 12 Feb 2025 01:08:35 +0000
DOM Volume @ Price Study Showing same volume every price
View Count: 443
[2020-09-28 00:52:12] |
User465507 - Posts: 74 |
What would cause the trading DOM study 'VBP' on the DOM to frequently show same volume traded at almost every price. The footprint seems to properly record it, but not the volume profile on the DOM. See example attached. Symbol is ETHUSD-BMEX. |
![]() Attachment Deleted. |
[2020-09-28 04:26:01] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
