Date/Time: Wed, 12 Feb 2025 01:11:42 +0000
Buy/Sell Market hot key
View Count: 609
[2020-09-27 17:08:13] |
Chap - Posts: 39 |
Hi. when I use hot keys for buy and sell market orders, with a previous 3 contracts configuration OCO order, when I press for a longer time the hot key, the number of contracts trade increase exponentially. how this can be avoid, even though pressing for long time the hot key, how the previous configuration OCO order can be respected without increasing the number of contracts. Thanks. |
[2020-09-28 10:09:48] |
You need to set a Position Limit for the symbol: Global Symbol Settings: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-28 10:09:56
