Date/Time: Wed, 12 Feb 2025 00:37:38 +0000
[User Discussion] - Cannot find AllowOppositeEntryWithOpposingPositionOrOrders
View Count: 443
[2020-09-27 05:36:19] |
User990275 - Posts: 26 |
Hello, the docs reference a variable AllowOppositeEntryWithOpposingPositionOrOrders for the Trading System Based on Alert Condition Study, but I do not see this variable listed in the Study Settings and Inputs. How can I set AllowOppositeEntryWithOpposingPositionOrOrders to True? Version: Sierra Chart 2135 Thanks Ajay |
[2020-09-27 09:42:16] |
That particular setting is not supported with that trading study. You would need to use the Spreadsheet System for Trading study instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-27 09:42:29
