Date/Time: Wed, 23 Sep 2026 18:28:02 +0000
Activity log - chart stats - not respecting load order fills from current day only
View Count: 828
[2020-09-26 19:20:20]
User100912 - Posts: 131
The "daily net p/l" column is being populated for symbols which I have not traded on Friday.
Order fills start date time is a date in August even though I have checked load order fills for current day only on the relevant chart.
imagesierra.png / V - Attached On 2020-09-26 19:19:57 UTC - Size: 63.8 KB - 369 views
[2020-09-27 09:56:01]
We see why a Trading DOM is loading all of the order fills and effectively disregarding that setting. This would not be a problem in a standard chart.
We also added this to the documentation:
When Load Order Fills for Current Day Only is enabled and a new trading day begins, prior order fills are not cleared from the chart unless the chart is recalculated and you are running version 2176 or higher. To recalculate the chart, select Chart >> Recalculate.
[2020-09-27 15:54:35]
Sorry, this issue is persisting through a restart, an upgrade to 2175, and reloading/recalculating each DOM. (after reload/recalculate, the symbol/chart appears at the bottom of the trade activity log charts stats list)
[2020-09-27 18:53:22]
This seems to be a recently introduced issue.
I will have DOMs on my chartbook and this interferes with correct calculation of daily P&L.
[2020-09-28 10:08:53]
We forgot to say that this is going to be resolved in the next release.
