Date/Time: Wed, 12 Feb 2025 00:46:26 +0000
Installation MacBook Pro on Windows 10 using Parallels
View Count: 761
[2020-09-26 15:31:44] |
DGee - Posts: 82 |
I am trying to install ver 2163 on a Macbook Pro using Parallels on Windows 10. Unfortunately it will not install. I use to have a much older version and decided to delete it and start over. Can you point me in the right direction here. I've attached the latest log on a unsuccessful attempt. Thank you.
Private File |
[2020-09-26 15:36:04] |
owendonk - Posts: 54 |
I'm running 2163 on Macbook Pro using Parallels on Windows 10 so I know it's possible. Good luck!
[2020-09-26 16:16:39] |
DGee - Posts: 82 |
Yes I use to run an older version. I'm not doubting it will work. Just trying to figure why it's not installing. Oh BTW- I've disabled any Anti-Virus or Malware software on this install.
[2020-09-26 16:26:39] |
DGee - Posts: 82 |
Ok.. never mind. I got it to work after further search on this thread. Thank you! Issues installing the software |
