Date/Time: Mon, 25 Nov 2024 12:43:11 +0000
Custom Period Presets
View Count: 1117
[2014-02-07 22:08:49] |
cazeek - Posts: 33 |
Hello, Is there a way to change the presets/buttons for the chart periods? In other words, I want a button for an 8H chart. Thanks, Steven |
[2014-02-07 22:24:46] |
Yes. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
