Date/Time: Wed, 12 Feb 2025 01:48:58 +0000
Sierra Chart Replay mode just shows 1 in the next Bid and Ask Price
View Count: 1087
[2020-09-25 23:24:46] |
TekinTrading - Posts: 8 |
HI Sierra Team Since I am using Sierra Chart, I try to set up the replay mode for DOM. Unfortunately it is not possible to show all die Limit Orders in the past. I tried everything. Same loaded days in the m1 chart & orderbook, record market depth data is on, the time settings are true, the chart interval Is equal or less than 10ms etc. I tried this for different markets (ES, 10 years treasury, Euro Stoxx..) but nothing works. I watched different YouTube explanation videos and tried their chartbooks. If I start the replay mode, the Limit orders switch to 1 and just show me only the next bid and ask price. What should I do? I read all of your treats about setting up replay mode.. Hope you can help me! |
[2020-09-28 10:00:50] |
Refer to the instructions here: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
