Date/Time: Wed, 12 Feb 2025 01:20:48 +0000
creating 5 tick chart
View Count: 644
[2020-09-25 14:26:21] |
User118473 - Posts: 16 |
hi, reaching out for help on creating/adding another 5 tick chart? i presently have 1.25 and 2.5 tick chart and would like to add 5 tick with same layout? thanks!
[2020-09-25 15:10:17] |
Ackin - Posts: 1865 |
Try Menu >> Chart >> Duplicate Chart and then on the newly created chart Menu >> Chart >> Chart settings .. Bar Period Type |
[2020-09-25 17:01:59] |
User90125 - Posts: 715 |
How does one configure and add a fractional tick chart like 1.25 ticks and 2.5 ticks in SC?
[2020-09-25 17:32:56] |
Sure he writes about the Range Per Bar chart, just misrepresenting the situation. There are many newcomers here.
[2020-09-28 09:49:49] |
Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
