Date/Time: Wed, 12 Feb 2025 04:29:25 +0000
[User Discussion] - Need help with swing pivot subgraph
View Count: 523
[2020-09-25 14:14:58] |
User454021 - Posts: 5 |
Hello, I'm looking for a study which generates pivot lines as subgraphs from swing high / low. Ideally only the last two extended until intersection. Any idea how to accomplish this? It's important that I can reference the lines in a formula / alert. Only visible lines do not help me. Thank you! |
[2020-09-25 14:53:18] |
Ackin - Posts: 1865 |
Look: Swing High and Low |
[2020-10-02 12:15:24] |
It doesn't seem to work. The lines have a subgraph but in the chart value window they always have a value of 0. However, if I set an alert like L < IDx.SG2 (swing low) or SG4 or 5 or 6), nothing happens, no alert created. |
[2020-10-02 14:07:56] |
User454021) If you write about my study: Everything works fine. You have probably chosen only a mode that displays the line in graphical mode (as a tool for manual trading). Write in the description of the study on my forum directly which visualization mode you want to use and it is not a problem to add an alert there. If you are writing about the Swing H / L study from the sierra chart, it is logical that you do not see anything there, because the Swing will be created back a few bars later, not immediately. Date Time Of Last Edit: 2020-10-02 14:09:54
