Date/Time: Wed, 12 Feb 2025 00:27:27 +0000
Reset Chart Stats
View Count: 1208
[2020-09-25 12:31:33] |
RMos22 - Posts: 27 |
If there are non zero values in Chart Stats in SIM mode when I open Sierra at the begining of the day (7 am EST), what is the safest procedure to clear these data?
[2020-09-25 15:13:54] |
Ackin - Posts: 1865 |
Clear Trade Simulation Orders & Data Trade Menu: Clear Trade Simulation Orders & Data (Trade menu) Menu >> Trade >> Clear Trade Simulation Orders & Data |
[2020-09-25 15:13:56] |
John - SC Support - Posts: 37891 |
Refer to the information here: Trade Menu: Clear Trade Simulation Orders & Data (Trade menu) Note the link to additional information about clearing trade simulation data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-25 20:01:09] |
Have a look at this setting: Chart Settings: Load Order Fills for Current Day Only (Chart >> Chart Settings >> Trading menu) You would then want to do a recalculation for all charts but we can see there is no command for that. But we will add one. Currently use this: Edit Menu: Edit >> Reload All Charts Generally we recommend not clearing order fills so you have a history of them. However, that is up to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-25 20:01:27
[2020-09-25 21:09:27] |
According to Sierra documentation, the setting 'LoadOrderfillsForCurrentDayonly' is only applicable to Non-Sim. accounts. Will 'Clear Trade Simulation Orders & Data' remove all records from the Trade Activity Log from previous days too? |
[2020-09-25 22:01:31] |
According to Sierra documentation, the setting 'LoadOrderfillsForCurrentDayonly' is only applicable to Non-Sim. accounts. Yes that is true.So instead you would want to use this setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Will 'Clear Trade Simulation Orders & Data' remove all records from the Trade Activity Log from previous days too? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-25 22:01:48
